Steer Axle hub keeps overheating R/S
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Kdub99, Jun 14, 2023.
  1. Kdub99
    Kdub99 Bobtail Member
    41
    19
    May 8, 2019
    My right side hub keeps overheating on steer axle. Changed all the bearings, races and internal parts.
    Happened 3 times over the year and always starts with hubcap starting to swell. This time the hubcap completey melted. Was absolutely fine in the morning but somewhere within 5 hours of driving it completely melted and looked like it was lit on fire.
    Any suggestions on what to look because every part was changed in March. And it only happens on the right side steer axle.
    Truck is 01 Peterbilt for reference
  3. W923
    W923 Road Train Member
    1,419
    4,389
    Feb 28, 2022
    Unless the bearings were severely over tightened or something was wrong possibly the hub cap is not deep enough and touching the end of the spindle I would be thinking it’s a break problem.
    Pictures might help identify the issue.
    Who’s been doing this work?
    D.Tibbitt Thanks this.
  4. Kdub99
    41
    19
    May 8, 2019
    Well that's what happened today. First time got it done at a shop at home then 2nd time on the road in MN and 3rd time again different shop at home. 3 different shop so I doubt all 3 overtightened.
  5. Siinman
    Siinman Road Train Member
    5,518
    14,195
    Mar 5, 2017
    Kansas City, MO.
    Is that rim messed up? Might be causing it if bent maybe?
  6. Kdub99
    41
    19
    May 8, 2019
    Rim doesn't seem to bent holding air just fine and all. Maybe can get it checked out next.
    Siinman Thanks this.
  7. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    I'd have the spindle checked out good. Could have been messed up after the first time. Bearings spinning on the spindle would be a guess
    Smellfunny, Siinman, D.Tibbitt and 2 others Thank this.
  8. Last Call
    Last Call Road Train Member
    7,568
    45,913
    Mar 15, 2021
    As hot as that looks from that picture .. I would do exactly like @lester said ..
    And I'd be doing it now you got some sort of issue going on in that hub causing those bearings to be getting that hot to cook the oil
    Siinman and D.Tibbitt Thank this.
  9. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Years ago my 2000 379 was eating outer wheel bearings on the steer axle. About l set a year. It got hot like yours did once too. I finally bought 2 new front hub assemblys. Never had another issue. I suspect the casting was off enough that that bearing surfaces were out of alignment. That will beat the daylights out the bearing set.
  10. Jubal Early Times
    3,069
    20,586
    Oct 17, 2022
    Check that spindle real good and replace that hub.
  11. Big Road Skateboard
    7,099
    40,297
    May 2, 2021
    Not much there. Brakes, drum, spindle, bearings, and a hub.
    Brakes should have created other symptoms. I've never seen a spindle cause that, but it's possible.
    I usually go back to installer error when it comes to bearings. Maybe a race isn't seated well? Hub not concentric?
    Fleetpride has these hubs on sale this month. While I don't use preset hubs personally, they are idiot proof. These come with both bearings, sleeve, and seal. Not sure if a nut is included.
    Install, torque, and done. No adjusting bearings.
