Steer axle weight
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by MJ1657, May 2, 2013.
  1. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    I have a question for you car haulers its just something i'm curious about.
    How are you not overweight on your steer axle? Seems like when you put a car on your rack above the cab and a car all the way forward behind the cab or sleeper it would give you a tremendous amount of weight on the steers.
  3. Rugerfan
    Rugerfan Road Train Member
    7,777
    39,950
    May 3, 2011
    Redding,CA
    good question... never thought of that until now that you said something. i would think the rack would transfer the weight to the back
    Big_jon Thanks this.
  4. MJ1657
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    Good point. I'm guessing the 5th wheel plate being so low and far back helps as well???
  5. Rugerfan
    7,777
    39,950
    May 3, 2011
    Redding,CA
    i would imagine it would. idk ive never been around car haulers but thats also a good point with the fifth wheel being so low it must transfer the weight to the back. it would have to otherwise theres no way thgey could haul cars over the top of the cab
    MJ1657 Thanks this.
  6. Thumper
    Thumper Medium Load Member
    497
    155
    Aug 22, 2008
    Depends on your steer tires and the state I run up to 14.000 on the steers because of the tires and the states I run in
    I am only around 14k when I have 2 x 2500s on top of the truck you can slide your number 2 deck back if you need to and also depends which way you turn your cars to throw the weight of the motor onto the steers,tandems are the trailer
    MJ1657 and Rugerfan Thank this.
  7. Pullin2
    Pullin2 Crusty Canuck
    1,991
    3,611
    Nov 5, 2011
    Whoville Pub, Long Island
    I can put 4 F150's across the top. On the tractor I back those on putting both engine weights over the 5th wheel (drives). The two on the trailer I drive on so the one in the third position has its engine weight on the drives as well. I'm using a Cottrell / Volvo quickloader.
    I have to do this in my area of operations because even thoo my steer axle is rated at 14,600, my permit is not. And even if it was, I'm running 275 tires, and around here, they play the 10 millimeter rule with tire width at the scales, so in metric, that allows me 5,500 kilograms max on my steers ...... don't ask .... it's to hard to explain ...... Google it first.
    eeb Thanks this.
  8. bigdogpile
    bigdogpile Road Train Member
    1,931
    1,463
    May 16, 2010
    fontana ca
    You can go up to 20k on a steer axle
    123456 Thanks this.
  9. Pullin2
    1,991
    3,611
    Nov 5, 2011
    True, but it doesn't happen often in car haul.
  10. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,845
    Jul 28, 2011
    Glasco,Ks.
    Just don't unhook your stinger trailer with your headrack full !!!
  11. Thumper
    497
    155
    Aug 22, 2008
    Being bob tail in a loaded carhauler is a weird feeling ive had to do it a few times you tend to take curves real slow
    KANSAS TRANSIT Thanks this.
