Steer tire balance
Discussion in 'Ask An Owner Operator' started by scoobertdoo, Sep 2, 2022.
What do you prefer?
  1. centramatic
    59.4%
  2. Bags
    18.8%
  3. weights
    21.9%
  1. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
  3. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    I have centramatic on mine. I prefer over weights because it balances the whole assembly. I haven't used bags.
  4. Big Road Skateboard
    7,098
    40,282
    May 2, 2021
    Bags or Centramatics, and bags for my preference due to cost. Spin balancing only affects thr tire and wheel, is worthless as soon as you pick up a rock, and even under ideal conditions, it's out od balance as the tire wears.
    Beads and centramatics change with all of those conditions, and balance the wheel end
  5. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    I don’t believe in the beads. I did centramatics a couple months ago and I love them. Got it off Amazon for cheaper than anywhere else.
  6. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    Have the centramatics on all 3 axles on both trucks. They definitely make a difference
  7. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,265
    Nov 16, 2012
    SW FLA
    I had centramatics on the entire truck and trailer on my last truck
    They were out of stock when I went to get them for the new rig but will be adding those when I can
  8. rollin coal
    rollin coal Road Train Member
    13,620
    27,998
    Mar 29, 2008
    TN
    Always had better wear and balance with ceramic beads. Somebody pointed out it's cheaper and easier to pour a few ounces of antifreeze inside the tires. I had some centramatics that got hauled off with scrap metal one time so not a fan.
  9. GYPSY65
    1,957
    5,265
    Nov 16, 2012
    SW FLA
    Never tried it but an old guy I met said he used golf balls??
    Maybe noisy when rolling slow?
    Maybe inside tire wear?
  10. Derailed
    Derailed Road Train Member
    2,384
    2,657
    Dec 10, 2008
    Upstate NY
    Have had good luck with centramatics on steers.
  11. TallJoe
    TallJoe Road Train Member
    7,490
    16,273
    Apr 12, 2016
    Chicagoland
    I've used centramatics on steers for years.
    They will do the job. The steers are lasting easy past 200 000 miles and then I put them on the trailer for additional couple of years. Round like a perfect circle.
    I did consider throwing bags of beads the last time I installed the steers but the guy who was installing them said that I was better off staying with the centramatics rings because he had seen them beads chewed up the inside of the tires pretty bad. He might have exaggerated a little but still convinced me not to experiment.
    I have also heard about golf balls method but for now I stick to the rings since they seem to do the job.
    Bean Jr., GYPSY65 and blairandgretchen Thank this.
