steer tire wear
Discussion in 'Trucks [ Eighteen Wheelers ]' started by joecitizen, May 19, 2013.
  1. joecitizen
    joecitizen Light Load Member
    242
    38
    Mar 15, 2009
    Tucson, AZ
    What is this steer tire wear indicating? Alignment, Shocks, Spring Shackles & Bushings? I have, in the last two months, replaced the bearings. First picture (from left to right) is the driver side, which is obviously wearing the outer edge. The passenger side is wearing a groove on the inside, kinda hard to see with this picture. Tires are Dunlop SP384, lp24.5 @ 100 psi.
  3. BullDoggin
    BullDoggin Light Load Member
    183
    56
    Jan 27, 2013
    your problem is in rear axle alignment...
  4. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    I have a 3-axle alignment scheduled for next week for the same wear.
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
  6. MNdriver
    7,985
    4,372
    Feb 24, 2012
    I'd almost lean that way, but suggest both really. A good 3-axle is just as critical. In my case, I just had mine done 55,000 miles ago and showing similar wear now.
  7. 2222
    2222 Bobtail Member
    what kind of truck ?
  8. Marlin46
    Marlin46 Medium Load Member
    504
    299
    Mar 17, 2010
    Atlanta, GA
    More than likely a 3 axle alignment is needed. As MN said, if the funds allow have the king pins checked / replaced as well.
  9. joecitizen
    242
    38
    Mar 15, 2009
    Tucson, AZ
    '93 FLD120.
    When I had the bearings replaced, the mechanic checked the kingpins and told me they seemed good to him. Looks like I will focus on a 3 axle alignment and go from there. The steering is not shimming or shaking. It does wander a bit, but I just figured it was the quality roads we all drive on causing that.
  10. MNdriver
    7,985
    4,372
    Feb 24, 2012
    Double check the fasteners on your spring hangers too.
    Crazier things have been seen.
  11. x#1
    x#1 Road Train Member
    1,773
    1,104
    Dec 24, 2009
    Cherokee County, Alabama
    a 53' dry box that i pull from time to time but did pull fulltime was out of alignment and caused that type wear on my steers.it was gone thru and aligned and the premature wear was eliminated on truck and trl.the wear was passenger side mainly but was working on the driver's side steer.
    it makes sense as a trl that dog legs or just out of alignment,will push the truck in a skewed fashion.i may get some argument here but the trl now pulls so smoothly(it is loaded up w/all the lightweight goodies and is superb for a dry box) and the wear on all 5 axles is normal or was up until i started pulling dumps.
    i am concerned regarding the spread axle frameless dump i'm pulling.time to have it all checked out as i have read plenty of negative stuff regarding the alignment issues on spreads.
    just sharing my personal experience from over the years-
    MNdriver Thanks this.
