Steer wheel bearing?
Discussion in 'Volvo Forum' started by Socal Xpress, Apr 3, 2016.
  1. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    The truck 2010 630 d13 10 speed 676k
    I hear a click/crunching noise from drivers side.and also the wheel moves in sync with noise. Only hear noise and vibration under 15mph. At speed no issues. I check oil and felt cover for extreme heat. Checked out fine.
    So could the wheel bearing be going bad?
  3. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    Dust shield rubbing the brake by chance?
    Socal Xpress Thanks this.
  4. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    I will have to look at that.
  5. Old school 362
    Old school 362 Medium Load Member
    392
    249
    Mar 6, 2016
    Pensacola Fl
    Are you running grease hubs? Or oil hubs. I would pull the cap and check bearings . If you have a jack handy. Jack up that Side feel for play. If you have any play get it fixed asap.
    Sometimes it seems it's coming from the left side. But can bee right side. Just my .02 cents.
    roshea Thanks this.
  6. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    The newer Volvos have sealed bearings, have to replace entire unit.
    Cannot repack bearings like on my '01.
  7. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    the one in my old freightliner is bad,down by the floor. it makes a laughable amount of noise too. yours looks newer,probably not the same setup.
  8. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Wheel bearimgs good on both sides but have movement from kingpinn on drivers side. I was told that a new Kingpin bushing kit could solve my issue.
