Steering box replacement and pitman arm rubbing bumper.
Discussion in 'Ask An Owner Operator' started by Luke700, May 25, 2022.
  1. Luke700
    Luke700 Light Load Member
    57
    26
    Oct 14, 2019
    Hey guys my steering box was recently changed. When I turn to the left the pitman arm is extending too far out and rubbing the bumper area. And it’s not turning equaling on both sides it’s turning less right and more left
  3. AModelCat
    164,923
    Pitman arm was probably set on the wrong spline. Check for timing marks on the arm and sector shaft.
  4. xsetra
    xsetra Road Train Member
    5,198
    7,149
    Aug 21, 2011
    What brand steering box?
    I had a procedure "timing" to follow when installing my last steering box. Search the internet for instructions and videos.
    Good luck.
  5. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Take it back to the fool that did the work.
  6. God prefers Diesels
    4,198
    22,265
    Jun 26, 2020
    South Texas
    Had the steering box replaced on my pickup, because it was under warranty. They called me when it was done: "Your truck is finished, and aligned, but the steering wheel is crooked now. Are you okay with that?"
    I'm sure you can guess my answer...
  7. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,896
    Nov 26, 2020
    Lmao, “hey sir! I know you paid for all these groceries, but can we keep half? For the other customers? Do you have a car outside? Can I let my cousin from out of stare borrow it for the year?”
    some people ask crackhead energy type questions I swear
    D.Tibbitt and God prefers Diesels Thank this.
  8. D.Tibbitt
    157,286
    I know the bill is $400 but i only got about 3 dollars in my pocket. Are you okay with that?
    God prefers Diesels Thanks this.
  9. Another Canadian driver
    Another Canadian driver Road Train Member
    1,181
    4,266
    Nov 14, 2021
    ALBERTA
    Bloody incompetents idiots.
    God prefers Diesels and D.Tibbitt Thank this.
  10. wis bang
    wis bang Road Train Member
    3,461
    4,109
    Jan 12, 2011
    Levittown, PA
    I spent one summer during college in a 'rebuild shop' for Chem Leaman the year Mack intoduced the '300'.
    We were doing some of the mack 'final inspection' on the new company trucks to help Mack clear up their backlog due to the new engine.
    Every truck had the steering box marked and pitman installed one tooth off.
    Floor jack under the center of the axle, count the turns lock to lock and come back 1/2 then measure the sloped side of the steering box with a protractor then move the Pitman one tooth, make a new mark on the shaft end and spray it all with a can of Royal Blue paint.
  11. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Yeah, that's unacceptable. Give 'em an inch, they'll take you a mile.
