Steering hard spots..
Discussion in 'Volvo Forum' started by Barser82, Feb 27, 2020.
  1. Barser82
    Barser82 Bobtail Member
    Anyone got issues with hard spot while steering at low speeds? I’ve replaced ps pump filter, and fluid. Was fine for about half a day then started back again. Might be pump or steer box? Any help.. thanks
  3. QUALITYTRUCK
    1,716
    1,644
    Jun 14, 2009
    romulus,mi
    You need to replace steering shaft. New shaft has replaceable u joint. When you remove yoke from gear box input shaft you will feel u joint "sticking"
    Bakerman and Newto Trucking Thank this.
  4. T One T
    T One T Bobtail Member
    34
    36
    Jun 25, 2019
    Illinois
    Had a recall for that same issue; felt like it sticks or stops for an instant and you can definitely feel it. This was on a Freightliner Century class....cant remember what year the truck was but it was in 1997 or 8 when it happened to us. It was a steering shaft issue like stated above...
  5. Bakerman
    Bakerman Road Train Member
    4,654
    8,775
    Jan 27, 2013
    Phoenix, AZ
    Yep, I had the same issue and replace the shaft with the new you joints and all is well.
    KB3MMX and QUALITYTRUCK Thank this.
  6. Death Hauler
    Death Hauler Bobtail Member
    31
    8
    Jul 6, 2017
    I literally just had this happen to me. Start by spraying the joints on the steering shaft with WD40 or something similar and you will probably almost immediately feel an improvement. If it feels better you can probably drive like that for a little longer but it will have to be replaced soon.
  7. sbreeden
    sbreeden Light Load Member
    73
    54
    Dec 15, 2016
    Had the issue, the wheel well plastic started rubbing on the steering shaft ujoint. Reposition it fixed my.
  8. Aria
    Aria Bobtail Member
    I lowered my pet 579 last year ,,, after that i got hard left turn and steer won’t back to center smoothly,, so i though is gear box i did changed pump and gear box but still have same issues,, would u help me with any idea ?
  9. KB3MMX
    KB3MMX Road Train Member
    2,953
    2,474
    Dec 29, 2014
    Orrstown, PA
    Try adding enough fluid to get to top of filter.. ignore the dipstick.
    I've had a clogged filter do the same thing you describe.
    I hope you didn't use Lucas or anything like that in the fluid. Synthetic ATF is the best thing you can use...no thick additives.
    Aria Thanks this.
  • Draft saved Draft deleted
