Steering problem in sharp turns, tires skip, rouring sound.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Adamprov3nch3r, Oct 16, 2021.
  1. Adamprov3nch3r
    Adamprov3nch3r Light Load Member
    62
    14
    Dec 26, 2020
    So I just had king pins replaced and engine mounts only on one side cheap ### boss a new tie rod because it was bent supposedly and new tires balanced put on.... So its always pulled to the right a little but it just started that when im making sharp turn especially a fast u turn the tires wanna like skip on me and at high rpms it kinda sounds like a roaring sound coming from the truck but if i turn the wheel ever so slightly just a hair to the left it goes away but as soon as i release the wheel its back any idea?
  3. Lazer
    Lazer Road Train Member
    1,830
    2,939
    Jan 22, 2017
    Was an ‘all axle alignment’ done?
  4. Adamprov3nch3r
    62
    14
    Dec 26, 2020
    No sir no alignment at all to any axles why u ask because of new tires?? I was going to pay for one last night but didnt wanna waste money if it wouldnt help and it was 120 for only the front
    steering axle
  5. Rideandrepair
    17,445
    56,605
    Aug 8, 2015
    Replaced Tie rod? Needs alignment. A small amount out of adjustment means a lot. I did my cars recently. Turning corners it skids and hops. I need an alignment!! I thought I measured and replaced them exactly. It steers terribly. Get an alignment, have them check the rest of the front end.
