Steering wheel alignment
Discussion in 'Volvo Forum' started by freight shaker, Apr 11, 2018.
  1. freight shaker
    freight shaker Light Load Member
    238
    227
    Dec 14, 2010
    Northern Illinois
    How hard is it to align the steering wheel while the truck (2016) is in for an alignment?
    It's at enough of an angle it blocks the oil pressure guage and is really annoying. The mechanic told me they can't align the steering wheel on a Volvo due to the stability control.
    Any truth to this?
    Thanks in advance.
  3. fatmike02
    fatmike02 Light Load Member
    127
    159
    Mar 1, 2018
    Alignment of the steering wheel is also done while getting an alignment. Tell the tech to make sure the steering wheel is aligned. If it’s isnt, it’s no big deal to pull the steering wheel and align it.
    freight shaker and Big_D409 Thank this.
  4. Big_D409
    Big_D409 Medium Load Member
    552
    729
    Dec 1, 2012
    Robertsdale, AL 36567
    Yeah isn't more than 15 minutes to pull it and center it. My old man said places are charging 65$ to do it.
    freight shaker Thanks this.
  5. Mudman78
    Mudman78 Light Load Member
    106
    108
    May 23, 2016
    Straightening the steering wheel can be done during the alignment, but you are correct, it will affect the traction control. The steering angle sensor under the steering wheel needs to be recalibrated. Bendix has free software you can download off their website. Hook up a laptop to the truck with an OBDII interface module and use the Bendix software to recalibrate the sensor. Basically you just drive straight for "X" amount of feet/yards and it will recalibrate itself.
    Volvo8873 and freight shaker Thank this.
  6. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Maybe,Got my Vovo aligned at Goodyear...and it Sucks...Steering wheel is a good turn to the Left ..WTF...I thought they "Did Alig
  7. BUMBACLADWAR
    1,899
    1,923
    Dec 5, 2013
  8. freight shaker
    238
    227
    Dec 14, 2010
    Northern Illinois
    Thanks again everyone for the help!
  9. Jacoooooooo
    Jacoooooooo Heavy Load Member
    747
    1,054
    Oct 20, 2013
    Just allign it on the shaft. No need to take off the wheel. One bolt.
  10. nutcase
    nutcase Light Load Member
    259
    100
    May 2, 2010
    Meridian, ID
    You can do it by pulling the steering column off at the power steering box. The shaft on the top of the box is splined so you can adjust the steering wheel and reattach the column.
    freight shaker and speedyk Thank this.
  11. shatteredsquare
    shatteredsquare Road Train Member
    1,403
    1,833
    May 23, 2014
    middle dirt
    find a large speed bump that's hard to see and hit it at 20 mph. make sure you hit it dead on. alignment fixed! (not joking, i fixed mine this morning in chicago)
