Steering wheel locks while doing a backing maneuver
Discussion in 'Questions From New Drivers' started by GTPablo, Jan 31, 2019.
  1. GTPablo
    GTPablo Bobtail Member
    13
    Feb 28, 2018
    Why does the steering wheel lock during a backing maneuver
  3. Snakeschasingcars
    Snakeschasingcars Heavy Load Member
    743
    1,570
    Mar 22, 2018
    It doesnt lock... You reached the end of the turninh radius. You can only turn the wheel so far...
    D.Tibbitt and Bakerman Thank this.
  4. GTPablo
    13
    Feb 28, 2018
    Thanks but that's nother it. Vehicle stopped I'm trying to straighten the wheel but steering wheel locks up would not move until I started backing again
  5. mindes
    mindes Medium Load Member
    626
    540
    Feb 17, 2015
    Crestview, Fl
    Something is binding because it is bent possibly. Tire in a hole or against a curb?
    Lepton1 Thanks this.
  6. GTPablo
    13
    Feb 28, 2018
    Someone said it's because my foot was on the brakes too heavy
  7. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    Do you think it might do that going forward? Find the problem now.
  8. GTPablo
    13
    Feb 28, 2018
  9. Redtwin
    Redtwin Road Train Member
    5,518
    7,694
    Aug 17, 2012
    PBC, FL
    What truck are you driving?. I had a '16 Freightliner Cascadia that developed a steering problem almost exactly as you are describing. It would lock up when turning especially when at slow speeds such as when backing and when loaded heavy. I wrote it up many times, the shop would change the fluid, bleed the pump grease kingpins etc but nothing worked. They insisted the PS pump was fine and the steering box turned smoothly.
    I turned in the truck with the issue never being resolved. I made sure to red tag it and told the fleet manager personally that the truck should not be issued until he test drove loaded and was satisfied.
  10. Roaddreamer
    Roaddreamer Bobtail Member
    39
    22
    Jun 2, 2018
    Have you checked your power steering fluid?
    Lepton1 and TripleSix Thank this.
  11. mindes
    626
    540
    Feb 17, 2015
    Crestview, Fl
    Try to recreate it in a safe spot. Try holding the brakes to the floor and turn the wheel; I doubt the brakes are the cause.
