Steering wheel wondering
Discussion in 'Car Hauler and Auto Carrier Trucking Forum' started by Edgar951, Dec 26, 2016.
  1. Edgar951
    Edgar951 Bobtail Member
    I have a 2014 Peterbilt and we took off the spacers to drop the front a little and took it to park house Fontana to fix the caster on it but I have the worst ride I've ever expirince on a truck... My truck wonders a hole lot and my steering wheel is really loose I can't even look at my phone for a second because I'll end up in the other lane, I've took it back and told parkhouse that it needs more caster and they told me that the caster is fine, can someone please help me out here
  3. xsetra
    xsetra Road Train Member
    5,196
    7,147
    Aug 21, 2011
    How much weight is bearing on your front axle? Does your truck hop, shutter or shake? Vibrations.
    Good luck.
  4. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    I can't see how removing the spacers would make your truck wander. I would be looking at everything that moves. U-joints , tie-rod ends , wheel bearings , king pins. Grab a hold of the steering shaft and see if you side to side free play. Sounds like something is worn out or out of adjustment.
  5. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I wonder some times too, wonder what the hell I'm doing here!
    KillingTime Thanks this.
  6. The Admiral
    894
    561
    Jul 18, 2010
    Akron,Ohio
    I wasn't very mechanical when I started. I was blessed to have some of the help I got through the years. Old timers that forgot more than I am ever going to learn.
  7. thelushlarry
    thelushlarry Road Train Member
    3,023
    9,002
    Jan 9, 2012
    glasgow ky
    I wonder why I wonder over yonder then I wonder back over here. Yet sometimes I wonder why I am so wonderful.
    KillingTime and Bakerman Thank this.
  8. sxdime
    sxdime Medium Load Member
    409
    551
    Nov 9, 2010
    Elkton MD
    There is reasons they put those parts in to begin with. You took (spacers) out? If you are talking about the ones on top of the springs that the shocks mount to you did nothing for ride height. If you took (spacers) out from the bottom you should of got a truck with a (car haul) axle if that is what you do. In taking these (spacers) out they did not change the U bolts then you better start there as they will run out of threads before truly tight.
    Diesel Dave, Terry270 and brian991219 Thank this.
  9. Diesel Dave
    9,654
    32,689
    Jan 20, 2010
    Hesperia, Ca.
    When you remove those bottom spacers, you changed the alignment AND the pitch of the driveline. If you don't have a vibration now, you soon will due to the u-joints wearing out. I have been there, done that. That's how I know. If you have a 2 or more inch spacer, just pick one up that is half of that. But you should have some kind of spacer in between. Also, there are wedges/shims in between. They should be put back the same way. As for alignment, any good alignment tech should of told you all this I just said. Try another shop. Bobs alignment in Victorville of the I- 15 and D St., is a good shop, short drive from funtuckty.
  10. MrEd
    MrEd Road Train Member
    2,196
    2,836
    Sep 2, 2011
    Winfred, SD
    There is a reason so many old timers say ya can't point a Pete down the road. You just sorta gotta herd it down the road. Never had a Pete yet with road manners. Maybe there is some trick I never learned. Like putting your seat all the way on the floor and all the way back. Something like that. I've never been extremely impressed with a Pete.
  11. Diesel Dave
    9,654
    32,689
    Jan 20, 2010
    Hesperia, Ca.
    You should try driving mine sometime. Straight as a narrow. Drives like a pick up and it doesn't recognize a pass, just keeps going.
    MrEd and CasanovaCruiser Thank this.
