Steering wheel yanking back and forth
Discussion in 'Freightliner Forum' started by PermanentTourist, Jul 7, 2022.
  1. PermanentTourist
    PermanentTourist Heavy Load Member
    749
    881
    Nov 9, 2016
    48 states + Canada
    While accelerating at low speeds, like 20 mph
    Nothing dangerous or uncontrollable, but kind of annoying and worrisome.
    Just an alignment issue hopefully? Or something more serious, like steering box going or suspension issue?
    New front shocks didn't help, and I have new bushings put in last year so it's not that either I don't think.
    2016 cascadia
  3. Rideandrepair
    17,579
    56,942
    Aug 8, 2015
    Tires? Sometimes I get that when they’re brand new, don’t know why, once I pick up speed they balance out. After a couple weeks, goes away.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Did it shake before and after the alignment, if the rear ends weren't done you need to have them aligned?
  5. bad-luck
    bad-luck Road Train Member
    3,454
    6,371
    Nov 16, 2013
    Baltimore, Maryland
    Have you checked the king pins?
  6. PermanentTourist
    749
    881
    Nov 9, 2016
    48 states + Canada
    Which king pins do you mean?
    Probably not the trailer king pin?
    Pardon my ignorance
  7. PermanentTourist
    749
    881
    Nov 9, 2016
    48 states + Canada
    I haven't had an alignment for a year, and I've been putting on other tires since then. It's probably just uneven tires, hopefully..
  8. bad-luck
    3,454
    6,371
    Nov 16, 2013
    Baltimore, Maryland
  9. bad-luck
    3,454
    6,371
    Nov 16, 2013
    Baltimore, Maryland
    The king pins are a component of the tractor front end. I am in an area where my data signal is really bad, otherwise I would try and post a diagram. Hopefully someone else will chime in.
    PermanentTourist Thanks this.
  10. baha
    4,137
    2,837
    Jul 25, 2013
    ga
    To check the king pins just jack up one side at a time of the FT. end and stick the tire bar in the low hole in the wheel and rock it back and forth there should be no movement if you see it moving look for any slop in bearings or king pins? When the wheels are back on the ground get someone to shake the steering and ck a) tie rod ends for play and steering box arm to box for slop?
    Reason for edit: More info
  11. PermanentTourist
    749
    881
    Nov 9, 2016
    48 states + Canada
    Cool, thanks! I'm gonna try that.
    However... the file you attached is about a cab heater cover of some kind.
    Rideandrepair and flood Thank this.
