Steering wobble columbia
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 377pete, Sep 27, 2020.
  1. 377pete
    377pete Light Load Member
    147
    14
    Oct 26, 2009
    dfw
    I bought this 2007 columbia, i did this before installing new steers. Well sometimes i would get a wobble on the steering wheel after hitting a bump on the road. Got new steer, new drag link and new alignment, guy said tie rods where good. Now it still does it, what can it be?
  3. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    left to right or up and down..
    Just cause its aligned doesnt mean they did it right....
    Are the tires mounted on a clean rim?
    Rim bent?.
    What ki da shape are the shocks in..
  4. zinita17601
    zinita17601 Road Train Member
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    I have the same problem,visually checked everything all looks good,i just found out that the bolt holding the pitman arm to the grooved steering box shaft is loose allowing the drag link to move back and forth,will stop soon and tighten it and will update.
    377pete Thanks this.
  5. rollin coal
    rollin coal Road Train Member
    13,631
    28,014
    Mar 29, 2008
    TN
    Keep an eye on that daily and if it works its self loose again order a new pitman arm.
  6. zinita17601
    1,324
    1,613
    Aug 19, 2010
    lancaster pa
    I did some research on here and found your post from 2018,i will do exactly what u suggested.thank you
    rollin coal Thanks this.
