Stereo Constantly on
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by BurjKhalifa, Jul 6, 2024.
  1. BurjKhalifa
    BurjKhalifa Bobtail Member
    20
    6
    Nov 22, 2023
    Hi, I have a 2000 peterbilt 37 ,it came with an aftermarket stereo and never turned off , I upgraded it anyways and assumed it was yellow and red wire together, but upon installing the new one, i wired red with red , and yellow with yellow i noticed that the stereo stays on with the key off. The red wire seems to have constant power while it should be ignition only
    It looks like no splices in the original harness now im stuck.
    Anyone know where to look?
  3. RockinChair
    RockinChair Road Train Member
    5,421
    14,648
    Feb 19, 2012
    Lubbock, TX & thereabouts
    Since the stereo works with the key off and the CB doesn't but you want it on all the time, maybe you could switch the wiring at the fuse/relay box.
  4. Lazer
    Lazer Road Train Member
    1,850
    2,984
    Jan 22, 2017
    The radio itself does not have a ‘power button’ or on/off, somewhere?
    BurjKhalifa Thanks this.
  5. Ridgeline
    22,782
    124,699
    Did you check these two with a volt meter before putting it in the slot?
  6. BurjKhalifa
    20
    6
    Nov 22, 2023
    nope, constantly , checked red wire ignition wire for it and its constant 12v
  7. BurjKhalifa
    20
    6
    Nov 22, 2023
    I checked it , red has constant 12v , and at the fuse box by feet the radio has no power. im assuming its spliced somewhere.
    My idea was to run a fuse tap to the circuit breaker instead. what do you think?
  8. BurjKhalifa
    20
    6
    Nov 22, 2023
    ok guys, so i removed random fuses and found that when i remove the "AUX FAN" fuse the stereo does turn off, so how do i proceed from there?
  9. skallagrime
    skallagrime Road Train Member
    3,855
    9,929
    Apr 10, 2012
    Indiana
    Why is this undesireable?
    Lotta time if im sitting with truck off i still want my radio on.
    Got so i normally splice yellow and red
    If you get real fancy and like me also really dont like the radio turning off every time you start the truck (disconnects radio, ande therefore bluetooth on crank), run new direct wire to headunit from house batteries, (fuse your positive at the battery in a weatherprotected inline fuse)
    If worried about parasitic draw, either remove headunit face on parking for a while, or add a dash mounted switch to kill power
  10. BurjKhalifa
    20
    6
    Nov 22, 2023
    Alrighthy guys, i just fuse tapped into the wiper blades, and i now have apple car play :D. thanks everyone IMG_0128.JPG IMG_0129.JPG
  11. The one california kid
    The one california kid Medium Load Member
    562
    940
    Oct 31, 2023
    He wouldn't have to switch, he could run a jumper wire off the red to his cb. I'm confused as to why it's a problem to have access to the stereo while the key is off? I ran mine that way, along with ,2 small amps straight to the batteries as well as a flat mini powered sub and played it all the time with key off and never had no problems starting the truck.
