Sterling with mercedees 2 emission codes
Discussion in 'Freightliner Forum' started by bowtieboy77, Nov 23, 2019.
  1. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    Hello I have a 2008 sterling with a mercedees engine. I have 2 codes
    1. doser fuel line pressure failed self test spn 4077 fmi 135
    2. Dpf zone 2 condition spn3719 fmi135
    My assumption is a problem with the doser fuel supply has caused incomplete regens and is plugging the dpf.
    How do I check or diagnose the doser fuel line for issues? Is this a common problem on mercedees engines? I only have a prolink ultra which is very limited as to how much I can do. Any info as to how to diagnose and repair this issue is appreciated.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,297
    Apr 9, 2009
    Humboldt, Sk
    is the fmi code 1, 3 or 5. no 135 . Or a 13 and a 5.
    the 4077 is the primary fault, the 3719 is the result of not being able to do a regen.
    Could be a fuelline leak to or at the dpf doser.
