Still working on my 13 speed swap
Discussion in 'Freightliner Forum' started by W Bench Farms, Jan 4, 2022.
  1. W Bench Farms
    W Bench Farms Light Load Member
    211
    351
    Oct 16, 2017
    Getting ready to finish up on the swap on my 95 FLD. Hopefully getting the driveshaft shortened and balanced tomorrow. Have a question on speed sensors. My original 15710 had a screw in 4 wire speed sensor. The new 16913 has push in sensors. Is there an adaptor or clamp available to use the screw in, or will I have to switch to a push in. If I have to go to a push in style, need to find the 4 wire for a Freightliner. Anyone have a part number?
    Bean Jr. Thanks this.
  3. little cat 500
    2,055
    1,099
    Jan 17, 2010
    Abbottstown PA
    last time i ran into the problem i took the little housing off the trans and put it on the other trans and keeped my sensor
  4. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    you can get just sensor housing with screw in type weller should be able to find one for you based on trans number.
  5. W Bench Farms
    211
    351
    Oct 16, 2017
    Ended up talking to a couple guys here, and think I have it figured out. Went to Freightliner, and got a 4 pin push in sensor with an adaptor harness. Only ended up totaling around $50. The other option was to use two sensors, but would still need adaptor pigtails for both.
    Rideandrepair Thanks this.
