Stop engine immediately
Discussion in 'Ask An Owner Operator' started by Adriantx, Jun 13, 2021.
  1. Adriantx
    Adriantx Light Load Member
    64
    17
    Dec 29, 2018
    I have a kenworth t680 every time I get a truck wash I get the STOP ENGIEN IMMEDIATELY CODE pop up I have read that ist becuse the ecm gets wet is thier any place in specific or something specific I can do to stop this code from poping up today june 13 the code stayed on for 2hrs after the wash so I did a reset and it's no longer there wondering now if I ####ed up? Also if any one knows how much is an ecm for a cummins isx someone told me there like 10k but I looked mine up and its only like $1600 was that guy just trying to me or why would he tell me that
  3. RunningAces
    RunningAces Road Train Member
    1,306
    2,584
    Jul 2, 2017
    Are you getting an engine wash when this happens? If so, stop it!
    Vampire, feldsforever and drivinhome Thank this.
  4. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    Do not let them point the hi pressure water near the ECM or wiring that leads out of ecm!!
    Vampire Thanks this.
  5. drivinhome
    drivinhome Light Load Member
    91
    102
    Sep 16, 2009
    Southeastern Mass
    The ECM is a computer and very sensitive to moisture. It’s ok to wash under the hood but be careful around it. It should be impenetrable to moisture but unfortunately it’s not. I have heard this before.
  6. roundhouse
    roundhouse Road Train Member
    3,213
    7,334
    Jul 11, 2018
    Yep
    I was just gonna say, stop gettin a truck wash , save the $$ and keep rolling.
    it usually doesn’t look much better after the wash anyway.
    There’s a reason the blue beacon truck wash is called “the streakin’ Beacon “
    feldsforever Thanks this.
  7. Adriantx
    64
    17
    Dec 29, 2018
    No I don't get engien wash to often I'm guessing it's just water that lands around with all the hoses they use
  8. Adriantx
    64
    17
    Dec 29, 2018
    They done its just water that's runs down I don't get engien Wash too often
    baha Thanks this.
  9. Adriantx
    64
    17
    Dec 29, 2018
    Yes I try my best but I think it's just water that runs down that wets it just enough
  10. AModelCat
    164,974
    I steam clean the engine of every vehicle I've ever owned, engines of trucks, heavy equipment etc and have never once had a code or issue arise because of it. You can spray water all over that engine and wiring with no worries. Its when you stick the wand tip 6 inches away from that stuff that you cause damage. Keep the tip 2 or 3 feet back it should never been an issue.
    Vampire, Siinman, drivinhome and 2 others Thank this.
  11. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    You need someone with computer to figure out what sensor cause STOP ENGINE and check sensor rubber cover.
