STOP ENGINE Kenworth t680 2017 paccar mx 13
Discussion in 'Kenworth Forum' started by Hakotrucking1905, Aug 5, 2021.
That truck should have a computer with touch screen. You should be able to see the engine faults on that.
no it doesn't
Have you checked the fluid levels? Particularly the coolant level.
coolant is full.sir .it is doing either while idling or driving and like I say it comes on one's I hit gas more it goes away and does it again in a hour or 2 / 3 hours
Not sure about the KW but the 389 I used to drive you could call an 800 number and they could give you an idea or point you in the right direction. Most likely they’ll give you the standard “it needs to go to a dealer “ reply. But it’s a start.
Hakotrucking1905 Thanks this. -
Am getting the same issue, but mine engine turns off by itself after 5 seconds. Not sure what causes it.
