stop engine light and warning buzzer
Discussion in 'International Forum' started by Thomas0810, Sep 19, 2011.
  1. Thomas0810
    Thomas0810 Road Train Member
    1,105
    209
    Jun 14, 2007
    BlueRidge Texas
    I drive a 09 prostar.Today out of the blue my engine stop light and buzzer came on a couple times.i immediately pulledover and as soon as i did each time the light and buzzer went away.oil and water levels are fine any ideas?
  3. Black_379
    Black_379 Light Load Member
    141
    65
    Aug 15, 2011
    Were you overheating?
  4. Thomas0810
    1,105
    209
    Jun 14, 2007
    BlueRidge Texas
    no normal temperature readings normal psi readings on oil pressure and lights and buzzer went off immediately each time i pulled off the road
  5. Dutch
    Dutch Light Load Member
    194
    58
    Commiefornia
    its hard to say with out hooking insite up and checking the fault codes, but the most common that would cause it can a crankcase filter pressure fault or coolant level.
  6. Thomas0810
    1,105
    209
    Jun 14, 2007
    BlueRidge Texas
    drove 469 miles today and never did it once go figure lol
  7. Heavyd
    Heavyd Road Train Member
    7,830
    6,282
    Feb 4, 2009
    Stop Engine light will come on for more serious problems. Such as low oil pressure, high temps and at level 4 regen. If your truck is programmed for shut down with low coolant I think the STOP light comes on too. Probably just a glitch. Keep an eye on your fluids and hammer down.
  8. Thomas0810
    1,105
    209
    Jun 14, 2007
    BlueRidge Texas
    yeah 600 miles today and it came on 3 times light and buzzer went off immediately before i could pull all the way over each time.noticed today my regen is not working thinking this is all related
  9. Sinanyane
    Sinanyane Bobtail Member
    Have a 2010 international pro star have this truck having normal oil and coolant levels .has had a buzzer and did Regen ..
  10. Heavyd
    7,830
    6,282
    Feb 4, 2009
