stop light shutdown @ 5 minutes idling
Discussion in 'Freightliner Forum' started by FLATBED2013, Mar 2, 2024.
  1. FLATBED2013
    FLATBED2013 Bobtail Member
    10
    4
    Feb 22, 2024
    2013 freightliner dd13 truck is running and driving fine... but at idle it runs for 5 minutes then check engine light starts flashing, stop light comes on simultaneously. both flash a few seconds and truck shuts off happens right at 5 minutes.
  3. wichris
    wichris Road Train Member
    4,500
    9,271
    Jan 17, 2011
    Because it's set with a 5 minute idle time.
  4. FLATBED2013
    10
    4
    Feb 22, 2024
    wasn't doing this last week..
  5. FLATBED2013
    10
    4
    Feb 22, 2024
    was not doing this last week
  6. Tb0n3
    Tb0n3 Road Train Member
    4,738
    9,652
    Oct 5, 2012
    Earth
    Is it possible a sensor which kept it from doing that failed? Does it shut off out of gear with the brakes set? Is it your truck or a company truck?
  7. FLATBED2013
    10
    4
    Feb 22, 2024
    Out of gear and brakes set only not while driving.
    My truck
  8. Tb0n3
    4,738
    9,652
    Oct 5, 2012
    Earth
    If it's the same timing then it's definitely related. If you let it time out normally does it give the same lights on the dash?
  9. Concorde
    Concorde Road Train Member
    5,482
    19,487
    Jun 29, 2016
    West Melbourne Florida
    How long have you had that tractor? Obviously if you had it for a long while you know something isn’t right.
    My 21 Pete would shut down after 5 minutes of idle but I could turn the cruise on , bump it up and it would idle indefinitely.
    My 23 Pete shuts down after 2 hours unless the outside temperature is 40 degrees or lower or 80 and higher. There’s no way to override it.
    My point is maybe your truck has multiple parameters set for the shutdown? Not sure if it’s even possible but could explain why it acted differently last week…
  10. 062
    062 Road Train Member
    6,332
    33,971
    Oct 20, 2013
    Been in the shop recently?
    If you tap the throttle do the lights go out?
  11. The one california kid
    The one california kid Medium Load Member
    562
    940
    Oct 31, 2023
    You could go old school on that one. Find the thermometer or temp sensor on it. You want heat longer? Strap some ice to it you want a/c longer, I won't say mount a bic lighter on it. Lol how about a battery operated heat gun? Works for me
    Concorde Thanks this.
