Stopping Distance
Discussion in 'Experienced Truckers' Advice' started by Professor Plum, Jun 2, 2021.
  1. Professor Plum
    Professor Plum Bobtail Member
    I already know that an empty trailer will have a longer stopping distance than a trailer with a max load but... Quick question: Which will have the shortest stopping distance at a rate of say 55mph, the bobtail or a tractor pulling an empty trailer?
  3. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Bobtail
    Empty trailer
    Loaded trailer.
    You can't stop 80,000 pounds faster then 35,000 or 20,000 pounds.
    Course. If you got crap brakes then it might be a different story.
  4. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,996
    19,137
    Mar 9, 2014
    In a van down by the River.
    Trailer. Bobtail will have no weight on its back axels
    AModelCat Thanks this.
  5. roundhouse
    roundhouse Road Train Member
    3,213
    7,334
    Jul 11, 2018
    That no weight is what enables you to stop faster .
    With nearly every tractor and trailer having anti lock brakes now , the bobtail isn’t a factor.
    The drive tires brake as hard as they can with out skidding .
  6. Linte_Loco
    Linte_Loco Road Train Member
    1,618
    6,485
    Apr 24, 2011
    LA (lower Alabama)
    Somewhere on the internet there is a video. I can’t remember where it is. Been tested like everything else lol. Can’t remember who won
  7. striker
    striker Road Train Member
    6,023
    6,439
    Aug 8, 2009
    Denver, Co
    Not true, newer tires can cause skidding, BTDT have the t-shirt, mug photos of damage and a copy of the repair bill.
    CrappieJunkie Thanks this.
  8. AModelCat
    164,678
    I have no front brakes. Have fun stopping quicker without a trailer.
  9. AModelCat
    164,678
    Unless I see proof otherwise I'm going with this answer. The trailer has 2 or 3 axles worth of brakes that more than make up for the trailer's tare weight. Plus it helps give the drive axles traction. Depending on 5th wheel placement may even transfer additional weight forward to the steer axle.
    kylefitzy, CrappieJunkie and MACK E-6 Thank this.
  10. MACK E-6
    50,029
    238,315
    ...Yet another on the long list of reasons that unlike some of the doofuses I work with, I refuse to run around with my fifth wheel slid all the way back.
  11. Wasted Thyme
    7,729
    38,310
    Jan 27, 2020
    GOAT watching
    Mine is one notch back from centered over the drives.
