Strange air leak
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Freightlinerbob, Dec 9, 2015.
  1. Freightlinerbob
    Freightlinerbob Road Train Member
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    The leak is on the "B" reservoir. Here are the symptoms:
    -Driving down the road the compressor cycles every few minutes.
    - When parked with parking brakes applied, it leaks just as fast.
    - When parked with parking brakes released, the leak seems to stop, more or less. (30 minutes to leak from 120 to 100 psi. )
    I've sprayed down everything I can think of with soapy water and can't find anything.
    Any ideas?
  3. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Sounds like a valve problem
  4. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
  5. AModelCat
    166,229
    Is B the primary or secondary reservoir?
    Have you checked the exhaust ports for leakage at every valve you can find? I would guess that maybe you have a valve that's leaking. Possibly a check valve in the air system sticking, which would cause you to only draw air from the B tank rather than blended air from both for the trailer supply or air accessories such as suspension.
  6. baha
    baha Road Train Member
    4,136
    2,837
    Jul 25, 2013
    ga
    CK. your firewall for air leaks from dash valve ex. line plastic line that is ending outside firewall so you will not hear air release from air brake valve inside dash so any leaks can be heard at eng. side of firewall, also ck. foot valve ex. port for leak?
  7. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    Yea the B tank is the secondary tank.
    I should mention that when parked with parking brakes released and the suspension relaxed the air is not leaking. It doesn't matter if the engine is running or off, it does not leak. This is just as if the truck was driving except that it isn't moving. Yet when it is moving, it leaks.
    Now I just parked it without applying parking brakes and let it settle for 10 minutes, then applied the parking brakes. The air leak is significantly reduced. Although it still leaks somewhat.
    I'm thinking its in the air suspension.
  8. Ozdriver
    Ozdriver Heavy Load Member
    770
    1,394
    Oct 16, 2015
    Australia
    It can be hard finding an air leak in an airbag especially when there's no weight on it. I've had to isolate each airbag in turn before I found a leak. I would first be isolating the whole suspension system from it's air supply as a first off. You'll need some 1/4" or 3/8" blanking plugs for this.
    AModelCat Thanks this.
  9. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Could be bad leveling valve .
    Park it and dump the air in suspention.
    Air ride cab??
    Could be leveling valve on there too.
  10. Freightlinerbob
    2,234
    1,316
    Jan 15, 2012
    West Coast B.C.
    Cab air bags and valve are new. I've double checked them as well. Parked with air suspension dumped. This made no difference, so I'm back to thinking its not the suspension.
  11. Ozdriver
    770
    1,394
    Oct 16, 2015
    Australia
    It isn't unheard of for the air from the primary tank to bleed back into the compressor. You could disconnect the line from the compressor port and see.
