Strange Nu Van winches
Discussion in 'Flatbed Trucking Forum' started by Doing_flatbed_nc, Dec 5, 2017.
  1. Doing_flatbed_nc
    Doing_flatbed_nc Medium Load Member
    585
    846
    Mar 3, 2016
    The 98 Curtainside I just bought needs some more winches.
    TruckPro has never seen these things.
    If you guys have any ideas where to pick some up instead of getting someone to weld pieces for me, I'd appreciate it.
  3. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    How do they come off? Just knock that pin out and remove the tab?
  4. Doing_flatbed_nc
    585
    846
    Mar 3, 2016
    There's a cut out under the bed. They slide. When they get to the cut out, you can tilt them out.
    I'm really at a loss. I need to run as soon as possible but five 4" and a dozen hand straps is going to make stuff difficult.
    4" hand straps might work. They may not bc the curtain
    I might suck it up and buy 7 four inch hand ratchets..., ouch.
  5. kylefitzy
    kylefitzy Road Train Member
    4,753
    19,806
    Aug 12, 2007
    Kansas city,Mo
    What's the underside of the trailer look like? I'm sure another clamp style winch could be used.
    Don't rule out 2" straps and ratchets. You have to use a few more 2" straps vs 4" but they work just as well. I used to work for a company that used 2" straps almost exclusively and nothing fell off.
    Doing_flatbed_nc Thanks this.
  6. Doing_flatbed_nc
    585
    846
    Mar 3, 2016
    I think I'm going to go with 15 2" straps and the 5 4" that are on the trailer.
    Did you ever run into any problems using 2" only?
  7. jamespmack
    216,640
    you can buy the winch its self. Then take to a fab shop and have them make the top plate ans weld it on.
  8. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    The 2in straps are not strong, like j/mack I think you can pay to have 8 or 9 of the sliding 4in winches welded up for you and keep the 2in just for small parts that need a extra strap?
  9. kylefitzy
    4,753
    19,806
    Aug 12, 2007
    Kansas city,Mo
    What do you mean the 2" straps are not strong? They typically have a ratting of 3333 pounds vs a typical 4" strap rating of 5400.
    2" straps work just fine. You just have to use a few more when compared to 4" straps a
    ChaoSS and Doing_flatbed_nc Thank this.
  10. Doing_flatbed_nc
    585
    846
    Mar 3, 2016
    I was thinking the same thing.
    They are not as strong as 4", but they're more than 50% as strong.
    I found a winch that I can bolt on. So I'm rolling with 12, 4" winches and 12, 2" hand straps.
    Well, as soon as the title comes
    kylefitzy Thanks this.
  11. Jumbo
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    Perhaps as your finances improve you should look into replacing the winch track to accept modern winches that are a little more readily available.
    whoopNride and Doing_flatbed_nc Thank this.
