Straps on winches
Discussion in 'Flatbed Trucking Forum' started by Dadetrucking305, Aug 15, 2021.
  1. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    984
    2,585
    Sep 15, 2011
    Cibolo,Texas
    I have been noticing that the people that keep the straps on winches are in an out of shippers and receivers much quicker than I am with having them rolled up inside my box.Was thinking of leaving them on the winches this week and seeing how it goes.I know that people can get hit by the hook but if I look under the trailer before I throw or yell out that the strap is going over it will mitigate the issue somewhat.What do y’all think?
    Kyle G. Thanks this.
  3. TripleSix
    133,302
    Ever notice how you see so many of those type trucks have all of their straps flapping while going down the load? Do what you like, but be mindful of your straps possibly loosening while you travel.
  4. skallagrime
    skallagrime Road Train Member
    3,855
    9,928
    Apr 10, 2012
    Indiana
    1. I think no, comstant uv damage on the most critical part of the strap strikes me as dumb, if you do this, replace straps yearly or sooner.
    If you must , get a winch bar, cut it down to 1 foot, wrap the hook end, dont just have it vertically. and *snug* down the winch with your short bar. Then push the winch backwards if theres any play.
    Theres more reasons i dislike straps staying on winches, but i will say that with practice, you should be just as fast throwing them fresh each time as most guys are at using from winches, i know im between 10 minutes faster to 10 minutes slower than them on the average.
  5. Big Road Skateboard
    7,098
    40,288
    May 2, 2021
    I think the more of the strap you have rolled on your winch, the more likely your strap is to loosen. Have no idea if they do, just something I thought.
    I worry more about how much time it takes to roll them up. I use a cordless drill with a rubber handled screwdriver to roll mine up.
  6. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,827
    Dec 7, 2015
    OK
    I carried two sets of straps one 30’ the other cut down to probably 20’ that I used for the shorter loads. Between having less strap to deal with and developing a system I was just as fast and sometimes faster without getting in a hurry than those who left the straps on the trailer. Throwing hooks can also damage the trailer and load.
  7. Linte_Loco
    Linte_Loco Road Train Member
    1,618
    6,485
    Apr 24, 2011
    LA (lower Alabama)
    Only practical for those who do the same thing day after day imo. 2-3 shingle/wood loads running local is where it helps
    jamespmack, cke, special-k and 4 others Thank this.
  8. mpd240
    mpd240 Road Train Member
    1,540
    3,625
    Sep 17, 2011
    Minnesota
    Wet straps on winches causes them to rust.
  9. FLHT
    FLHT Road Train Member
    1,429
    2,546
    Aug 2, 2014
    Get a Allan Wrench the biggest that will fit the drill chuck.
    Angle drill works better than a regular drill .
  10. bonder45
    bonder45 Road Train Member
    1,803
    5,452
    Oct 2, 2011
    Williston, ND
    I feel if you have a winch winder you can be just as fast.
    cke, Dadetrucking305 and lester Thank this.
  11. skallagrime
    3,855
    9,928
    Apr 10, 2012
    Indiana
    3/8 is about right, make sure its long enough, but not *too* long
    cke and Dadetrucking305 Thank this.
