Stretched VNL
Discussion in 'Volvo Forum' started by rhitrucking, Apr 26, 2017.
  1. rhitrucking
    rhitrucking Light Load Member
    163
    73
    Feb 7, 2017
    stretched a 2011 VNL D11 with Ishift to 320" wheelbase. I am having an issue on turns from a dead stop or when going under 5 mph. About halfway through the turn, there is a dead spot in the throttle response for about 3 seconds. Works perfectly when going straight. its not shifting, and all throttle response is gone for those few seconds. I am thinking it might be something with rear wheel speed going that much slower than fronts around corners. Any insight or anyone know of a solution? thanks
  3. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    it might have something to do with this do you have any kind of tcs light coming in the dash when this is happening. need to narrow down if it is from abs system or tcs system.
  4. rhitrucking
    163
    73
    Feb 7, 2017
    thanks for the reply...I have no lights resulting. Checking diagnostic history I have this, which I am fairly certain was there before the stretch
    MID 136 SID 69 FMI 2
  5. rhitrucking
    163
    73
    Feb 7, 2017
    here is a photo
  6. Dave_in_AZ
    425,758
  7. Ridgeline
    22,732
    123,561
    That's your anti brake error code, did you buy a new harness for the ABS modules or just splice them? YOU should buy a new harness when you stretch the frame.
  8. rhitrucking
    163
    73
    Feb 7, 2017
    not positive, the stretch was done at a shop. I will have to go look.
