Stryker 655 HELP Please !!!!!!
Discussion in 'CB Radio Forum' started by mcdowelljason, Feb 22, 2013.
  1. mcdowelljason
    mcdowelljason Bobtail Member
    Can some one help me I bought a Stryker 655 I need to know what all the buttons and knobs should be set on and where the meter is there is a function button what should all the stuff in the function setting be set on thanks
  3. Zapper
    Zapper Bobtail Member
    8
    12
    Dec 8, 2012
    I have the 655 I got for Christmas from my wife. I like it alot best radio I've ever had. You run D band for CB radio channels. I don't use roger beep and only a little bit of echo or talk back. I use a Wilson trucker 2000 on the air line hose bracket on the back of the cab. Shielded coax on 2013 Cascadia day cab. SWR is never higher than 1.5 on any channel.
  4. mcdowelljason
    Thanks for advice iam on d to but know one can hear me and when someone talks I can hear there talking but can't understand them . My swr is on 3.5 on all channels
  5. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    You need to get your SWR down to 2.0:1 or less or you will risk damaging the radio. Check your antenna. Make sure it's the right antenna for CB use. Make sure it doesn't have water in the loading coil. (if so equipped). Make sure the antenna is not shorted to the truck. Post pics of your antenna set up.
    Then check the coax and make sure it's not shorted or pinched.
    Are you going off of the radios SWR meter? it's always best to buy an external meter for SWR checks.
    Your radio has a freq. meter. make sure you're between 26.965 and 27.405. That's the CB band. Anything else is not the CB band.
    Anything 28.000 on up is 10 meters-don't operate there unless you have a license.
    Keep the AM-FM-PA switch to AM. If it's on FM the others might not hear you.
  6. Voltrucker
    Voltrucker Medium Load Member
    467
    133
    Sep 24, 2012
    West TN
    Have you had the radio converted?
  7. sidepocket
    sidepocket Light Load Member
    268
    88
    Mar 1, 2011
    louisa, va
    You can hear intelegence but not understand it. If its has the option for USB or LSB don't use either. Lol. Those are side bands. As in single.
  8. Turbo-T
    1,953
    708
    May 31, 2009
    I might be wrong but I don't believe the 655 is a single sideband rig. An export, yes. That's why I mentioned about ensuring the radio isn't on FM.
  9. Zapper
    8
    12
    Dec 8, 2012
    The 955 is the SSB radio 655 AM/FM only.
    Timin770 and sidepocket Thank this.
  10. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
