Stryker 955. adequate power source
Discussion in 'CB Radio Forum' started by 2hot2handle, Mar 19, 2019.
  1. 2hot2handle
    2hot2handle Light Load Member
    67
    34
    Aug 25, 2015
    Looking to purchase the Stryker 955hpc radio for my 2011 Freightliner Columbia. I know it needs the mod to be converted to 11 meter which I can do but do I need to run the power source for this radio straight from the batteries or can I use the provided power output that is used for a regular cb that came with the truck. Thanks
  3. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    I would just test fit radio up there to see if your ok with it 1st...
    Consider running your fresh coax to and power/gnd..Wouldnt use factory supplied..Its most likely not gonna give it a good constant power it needs....
    If you do use a new power gnd wire,go 10ga..
  4. 2hot2handle
    67
    34
    Aug 25, 2015
    Okay thanks. What type of fuse would you recommend in line?
  5. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Yeap...Those glass fuses are a bit wimpy but stick close to same rateing..
  6. craig_sez
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    after watching the vid go to the comments and supplys you will need are there..You just pick it up from who you seem fit to..Makes a diff..
