Stuck Wheel/Rim Removal
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Pappy77, Aug 30, 2019.
  1. Truckers Report Jobs
  2. CountryBumkin
    CountryBumkin Bobtail Member
    43
    39
    Jun 4, 2018
    I've never come across a truck wheel I couldn't knock free with a sledge from the backside.
    I think the shock from a hit from a sledge would work much better than a puller (i.e. a steady increasing pressure until it breaks loose) unless you are using the puller and sledge together.
    I remember a backhoe tire that wouldn't come off. The tire guy showed me a trick - just loosen the the nuts (or bolts in case of tractor) a little then drive the tractor in a figure-8 a couple of times in the yard. That loosens the wheel pretty quick.
    Super_Trucker and PE_T Thank this.
  3. lwlevens
    lwlevens Medium Load Member
    623
    427
    Feb 9, 2018
    ^^^I was just going to say that.^^^
    PE_T Thanks this.
  4. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    If you loosen the lug nut and run them back on hand tight and drive it a 300 yards works for me.
    Collie and PE_T Thank this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,778
    9,212
    Jul 12, 2017
    Porta-power across to the other side pushes them off easy if the are stuck good. I have had to do this a few times. Getting too old to swing a sledge all day and work smarter. Plus its way less damaging to the wheels and hitting the rubber just doesnt cut it and just bounces off.
    PE_T and Rideandrepair Thank this.
