Stud Installation Question...
Discussion in 'CB Radio Forum' started by hawkjr, Oct 4, 2011.
  1. hawkjr
    hawkjr Road Train Member
    1,652
    638
    Feb 28, 2010
    Virginia
    i feel embrassed asking this question but i got a T660 and im trying to install two new whips (the hustlers i inquired about in a previous thread) but everytime i start screwing the antenna down in to the the coax, the coax starts to turn along with the antenna... i tried using an wrench and pliers to hold the coax in place while tightening the antenna but that didnt work.... is it something im doing wrong hear?? or should i just swallow my pride and just take it to an professional... and by the way the stud is an standard truck spec sold at your pilots and flying j's....
  3. hawkjr
    1,652
    638
    Feb 28, 2010
    Virginia
    also the factory whip will screw back on with no problem
  4. mike5511
    mike5511 Road Train Member
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    Is this what you're using????
  5. hawkjr
    1,652
    638
    Feb 28, 2010
    Virginia
  6. mike5511
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    I guess I don't understand what the problem is. The plastic washer should be on top of the bracket. Hold the hex nut under the bracket with a wrench, tighten the nut above the plastic washer. Be careful not to over tighten and ruin the plastic washer. When screwing in antenna, hold the nut above the plastic washer so it won't turn and tighten the antenna into the nut.
    Does this help?
  7. hawkjr
    1,652
    638
    Feb 28, 2010
    Virginia
    yeah i was missing the plastic washer, all is well... appreciate the help
  8. Mekanic
    Mekanic Light Load Member
    57
    19
    Aug 6, 2011
    southern Ohio
    Missing?? I hope you didn't key up the mic with it like that. that could be BAD for the radio's life span.
  9. hawkjr
    1,652
    638
    Feb 28, 2010
    Virginia
    no sir...once i couldn't correct that problem i put the factory whips back on..... i corrected and everything fine with the current setup i have now..
  10. mike5511
    3,156
    1,546
    May 15, 2011
    NW Arkansas
    sounds like you got it. How do those Hustler's work? What kind of SWR did they have?
  11. hawkjr
    1,652
    638
    Feb 28, 2010
    Virginia
    since my mirrors sit low, the best the guy could get it was 1.3, i've yet to see how good i'm getting out, the radio im using it with is a peaked and tune Cobra 25 Nightwatch...
