Studying for CDL Permit: Have a question!
Discussion in 'Questions From New Drivers' started by texasbbqbest, Jan 21, 2015.
  1. texasbbqbest
    texasbbqbest Road Train Member
    1,088
    1,962
    Dec 9, 2014
    Minneapolis, MN
    Hey guys!
    I'm studying for my CDL Permit and I'm on the Combination Vehicle section.
    It mentions that "bobtail" tractors can take longer to stop than tractor-trailers loaded to its max gross weight, but it doesn't say why that is.
    Can anyone give me any insight as to why that would be?
    I would think that a fully loaded tractor-trailer would take more time because it has more mass, but I'm not correct according to the Texas CDL manual.
    Thanks in advance!
  3. dutchieinquebec
    dutchieinquebec Road Train Member
    1,282
    4,872
    Sep 30, 2012
    Granby.QC
    10 wheels versus 18 wheels maybe ???
  4. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    Trucks are designed to have a trailer and some weight on them. Without that the rear wheels can tend to skid while braking.
    The tractor in my signature pic is no fun to bobtail if the roads are wet or slippery.
    texasbbqbest Thanks this.
  5. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    because the brakes are setup for pulling 80k lbs. easier to loose control/traction bobtail
  6. texasbbqbest
    1,088
    1,962
    Dec 9, 2014
    Minneapolis, MN
    Ah okay. So the lack of weight/mass make traction not so great, therefore, the tractor is more likely to skid.
    I understand now.
    MJ1657 Thanks this.
  7. p47
    p47 Light Load Member
    72
    48
    Jan 18, 2014
    central mn
    look at the tires of a fully loaded truck and an empty one. the tires on a loaded truck are "flatter". ie: more surface area. also the front brakes are set up with a proportioning valve, meaning when you apply 20#'s of pressure, the front breaks only get 10#'s. this prevents the front tires front skidding .
  8. texasbbqbest
    1,088
    1,962
    Dec 9, 2014
    Minneapolis, MN
    Thank you! I'm sure most of this stuff I'm reading will make more sense when I actually get to my hands-on training.
  9. Arielit0oo
    Arielit0oo Light Load Member
    187
    108
    Jul 6, 2014
    Tacoma, WA
    Yeah, once you bobtail, you'll see why.
  10. Lepton1
    Lepton1 Road Train Member
    12,647
    25,589
    Nov 23, 2012
    Yukon, OK
    I scaled my bobtail with about 11,500 lbs on the steer axles (5,750 lbs per tire) and 8,500 lbs for the drives (1062.5 lbs per tire). Same surface area per tire but only 18% the weight. When you brake weight is thrown forward onto the steers and the drives don't have much weight to grab the road.
    The only time I've ever smoked the tires braking was bobtail when a traffic light changed to red and I had a cloud of smoke waft through the intersection as I barely stopped by the middle of the cross walk. That was on dry pavement.
    Other than the limitations of braking you have to pay attention to the fact that rolling a bobtail is almost easier than when you have a trailer. You can't corner. It may feel like a sportscar when you accelerate, but cornering and stopping are an entirely different matter.
  11. TNMT
    TNMT Light Load Member
    226
    229
    Nov 11, 2008
    Front of keyboard
    Reason why most companies forbid bob tail. Only with their permission.
