Sudden Stop Sends Pipes Into Truck Cab
Discussion in 'Trucking Accidents' started by mjd4277, Nov 29, 2024.
  1. Truckers Report Jobs
  2. Arctic_fox
    4,808
    27,509
    Sep 16, 2016
  3. broke down plumber
    4,728
    38,294
    Jan 25, 2024
    That #### steel pipe is heavy , ran some 4'' viktolic steel as the hvac chiller trunkline , took 6 men to carry a 20ft stick to the fitment station .
  4. 201
    201 Road Train Member
    13,010
    26,847
    Apr 16, 2014
    high plains colorado
    Only a maroon would pull a flatbed with no headache rack. They call it a "headache" rack for a reason.
  5. MACK E-6
    50,618
    244,554
    Back when I was in the trade, there was this old high school in Baltimore that was undergoing complete renovations. They wound up with 8” for their incoming water main. In order to get this stuff into the basement, they core drilled a hole through the brick wall and the whole crew slid each stick through the hole. That was brutal.
  6. Grumppy
    3,309
    11,896
    Dec 11, 2010
    West Monroe, La
    "As a result of the sudden braking, “three solid pipes shifted"
    Wait, what???
    Reporters...... :rolleyes:
  7. Long FLD
    Long FLD Road Train Member
    13,410
    56,806
    Mar 4, 2015
    If things are done properly it’s a non issue. In this instance of shorter pipe ( I’m assuming that because you can’t see any of the failed securement in the photos) a headache rack wouldn’t have don’t much because the pipe would’ve already been moving at whatever the truck speed was by the time it hit the headache rack. This person would’ve been better off building a bulkhead from his dunnage right in front of the pipe he was hauling. But I’m sure that would’ve been too much work because it was only a couple pieces.
    201 Thanks this.
  8. broke down plumber
    4,728
    38,294
    Jan 25, 2024
    Lol a solid pipe is a bar ? Yep bar of steel
  9. 201
    13,010
    26,847
    Apr 16, 2014
    Bulkhead on the trailer is what I meant. Hey, I'm old and confused easily,,:confused: I've seen flatbeds with no bulkhead and the driver wrapped chains around the front of the load, like a bulkhead.
  10. 86scotty
    86scotty Road Train Member
    4,903
    13,588
    Aug 27, 2017
    Appalachia
    Whatever that pipe is it put some impressively clean holes in the back wall of that cab. I'm impressed.
    Sons Hero and broke down plumber Thank this.
