Suggestions for Steer Tires
Discussion in 'Ask An Owner Operator' started by Jed2009, Feb 12, 2021.
  1. Jed2009
    Jed2009 Light Load Member
    195
    573
    Jan 8, 2020
    Midwest
    Looking at some new steer tires within a couple months. May will be the end of my first year as an OO. I had new Chinese ones put on 80k ago and they are wearing well and evenly but approaching end of life. I would buy them again but want I put from others. I know there’s better tires.
    Looking for suggestions and input on your favorite steer tires and what you’ve had success with in the past. My dad runs Highway Controls and says he’ll use them forever. Share your thoughts. 24.5” wheels FWIW.
    Edit: Midwest, dry van, 50/50 mix of interstate and highway / county roads.
  3. Spyro2112
    Spyro2112 Medium Load Member
    623
    433
    Mar 17, 2018
    22s what and where do u drive, off road alot or sometime, Kelly's,
    Rideandrepair Thanks this.
  4. Jed2009
    195
    573
    Jan 8, 2020
    Midwest
    Midwest. Half and half interstate and highway/county roads. Dry van.
  5. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,827
    Dec 7, 2015
    OK
    I’ve had good luck with Yokohama ry617
    rokue and Rideandrepair Thank this.
  6. DUNE-T
    DUNE-T Road Train Member
    7,046
    17,162
    May 10, 2015
    Detroit, MI
    I had the best experience with Michelin X line energy Z 16 ply.
  7. 86scotty
    86scotty Road Train Member
    4,706
    12,917
    Aug 27, 2017
    Appalachia
    I love the tires but they are the most expensive you can buy. This could just be bad luck but I've had more trouble with Michelin steers than any other.
    I switched to MUCH cheaper Firestones about 6 months ago. They make a little noise but have been trouble free and are wearing well. 507's I think?
  8. joey8686
    joey8686 Light Load Member
    131
    154
    Jul 1, 2014
    Firestones are great and priced very reasonable, Goodyear’s are junk worse than Chinese and priced almost as bad as Michelin’s
  9. Midwest Trucker
    5,914
    21,388
    Aug 31, 2018
    The latest Bridgestones is what I’m running right now. Otherwise I’d probably go a Michelin. I’ve ran Goodyear’s and Firestone’s but always get funny wear happening on them.
    The Bridgestones as long as you have an alignment done and replace the shocks at the same time, will go 175,000 miles with ease. You could push for 200 but with steers why take the chance.
    If you run more local you could try the Kelly’s. I hadn’t ran them in years but always did well for me. Just not real fuel efficient with rolling resistance.
  10. DUNE-T
    7,046
    17,162
    May 10, 2015
    Detroit, MI
    Couple of months ago I couldn't find Michelin in stock anywhere local, so I got Yoko 701zl for $375 and Continental HS3 for $425, will see how that goes
    Rideandrepair and 86scotty Thank this.
  11. bad-luck
    bad-luck Road Train Member
    3,438
    6,331
    Nov 16, 2013
    Baltimore, Maryland
    I run Firestone FS591. On my third set, got 170k out of them. My recommendation is to not run cheap tires on your steers, stay away from Chinese.
