Suggestions
Discussion in 'Flatbed Trucking Forum' started by blacklabel, Nov 3, 2019.
  1. blacklabel
    blacklabel Heavy Load Member
    870
    1,268
    Nov 6, 2011
    MO
    I've got an application in with the big blue star, not sure what trailer to get.
    53 lp on with 17.5 ramps and boxes is for sure.... Not sure if I should get a 3 axle like I had previously. Any thoughts would be appreciated.
  3. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    On 17.5 rubber id suggest 3 axles unless youre strictly light and slow. On 22.5 id run a standard spread unless you are into OSOW and permits. JMHO, YMMV etc.
    singlescrewshaker and blacklabel Thank this.
  4. blacklabel
    870
    1,268
    Nov 6, 2011
    MO
    I was leaning towards the 3 axles just thought maybe someone would chime in and show me something I was over looking
  5. singlescrewshaker
    4,868
    42,612
    Dec 31, 2017
    Little Havana, FL
    You run into tire trouble already pulling the lo deck..?
  6. whoopNride
    whoopNride Road Train Member
    1,649
    5,015
    Jan 13, 2008
    Miss.
    nikmirbre and blacklabel Thank this.
  7. FoolsErrand
    2,877
    12,169
    Sep 15, 2017
    No but i only pulled it about 200 miles during cool weather and went real easy. Im told that its had THREE sets of tires due to blowouts, before my time. It has sat the entire 8 months or so i been there and im first to hook into it because my flat was down.
    Its been converted to 8 lug 17.5s from standard axles by prior owner who i assume was setup for air handlers and such. Deck height is 36" but the ride height valve is set way high. I bet it can come down 4" or so without rubbing for lighter loads. Which are nonexistant in stone. 47k and up with lots of curbs and jack knifing.
    blacklabel and singlescrewshaker Thank this.
  8. nikmirbre
    nikmirbre Road Train Member
    5,590
    10,358
    Jul 27, 2011
    High Point NC
    If you’re talking about buying a trailer I’d go with the 53 lo pro.
    As far as 3 axles, it can be hit and miss, sometimes more hit than miss or vice versa. But I’d encourage you to set yourself apart by going with a 3 axle
    Tug Toy, blacklabel, cke and 1 other person Thank this.
  9. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    iirc, there is three different size 17.5's, the little 215 tires do not stand up to too much speed in my experience. They would hold up a load, just take it easy.
    The 235 seems to do much better.
  10. FoolsErrand
    2,877
    12,169
    Sep 15, 2017
    Yeah these were 215s. Cant hammer em like an 11R 24.5
  11. blacklabel
    870
    1,268
    Nov 6, 2011
    MO
    That was the big reason, and when a load pops up that pays to drop that axle I can grab it
    FoolsErrand Thanks this.
