Super 10 problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by little cat 500, Apr 7, 2020.
  1. little cat 500
    2,060
    1,107
    Jan 17, 2010
    Abbottstown PA
    Super ten in 96 freightliner worked fine all day got to were I was doing went to downshift now nothing wont move in any gear clutch seams to be working trans in not making any noise can feel it go in every gear but no power out the back
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,536
    6,605
    Aug 26, 2014
    Will it move with the P/D locked?
    SAR and spsauerland Thank this.
  4. Muddydog79
    Muddydog79 Heavy Load Member
    820
    2,147
    Apr 14, 2016
    See if your driveshaft is laying in the ground
    HoneyBadger67 Thanks this.
  5. little cat 500
    2,060
    1,107
    Jan 17, 2010
    Abbottstown PA
  6. little cat 500
    2,060
    1,107
    Jan 17, 2010
    Abbottstown PA
    No it dont move with power divider no power coming out trans but trans is quite no grinding or explosions
  7. little cat 500
    2,060
    1,107
    Jan 17, 2010
    Abbottstown PA
    I've been running this truck a few years no problems with trans till now
  8. little cat 500
    2,060
    1,107
    Jan 17, 2010
    Abbottstown PA
    Found it fork broke in back half of trans
    BoxCarKidd and Muddydog79 Thank this.
  9. BoxCarKidd
    4,536
    6,605
    Aug 26, 2014
    Been there done that. Took the back off it in the fertilizer building where it was. The shaft for the fork broke on ours. Replaced that and it is still running 6? years later. Ours broken where the resese for the fork lock bolt is.
    Hope you got that worked out OK.
  10. little cat 500
    2,060
    1,107
    Jan 17, 2010
    Abbottstown PA
    shop in Michigan got me fixed up run it 660 miles today shift fine
    BoxCarKidd Thanks this.
