Super 10 to 18 spd
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by drewfarmsllc, May 21, 2022.
  1. drewfarmsllc
    drewfarmsllc Light Load Member
    84
    32
    Oct 18, 2008
    South Carolina
    I have a 98 379 with a 12.7 Detroit and super 10 trans. I want to put an 18 speed in but not sure all in entails. How do make sure I get the correct trans? Is there a place I can put my old trans number and it will let me know what I can use?? Ratios and length
  3. kranky1
    kranky1 Road Train Member
    2,253
    8,855
    Sep 16, 2015
    Ontario, Canada
    All you have to do is compare the high gear ratio in the 10 to the high gear ratios in an RTO and RTOO 18spd. You’re probably going to end up a little faster with a single over, and the double over might be ridiculous.
  4. RockinChair
    RockinChair Road Train Member
    5,386
    14,447
    Feb 19, 2012
    Lubbock, TX & thereabouts
    What's the number of your current transmission?
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,551
    6,641
    Aug 26, 2014
    Search Eaton Fuller transmission ratios. If it is still on line it lists all the transmissions, ratios and length.
    That is a pretty direct swap if the replacement has the same shift tower location. Yoke is the same size or will swap. Halo or no Halo, not a concern if it comes with a bell housing.
  6. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    Super ten is the same length as a 13 or 18 direct swap except the shifter tower on the super ten is different
    Roger McG and LameMule Thank this.
  7. LameMule
    LameMule Road Train Member
    1,148
    7,418
    Jan 19, 2020
    Montana
    Pretty straightforward install from my experience. New clutch and clutch brake and a yoke to match your driveline. You will likely need to go to a driveline shop to have it shortened or lengthened depending on the conversion. New trans should come with shifter and color coded airlines.
  8. drewfarmsllc
    84
    32
    Oct 18, 2008
    South Carolina
    Thanks for the replys
