Super ten shifting on grades, what am I doing wrong?
Discussion in 'Questions From New Drivers' started by Carguy94, Dec 17, 2018.
  1. Carguy94
    Carguy94 Bobtail Member
    16
    10
    Nov 16, 2017
    I just got my license not to long ago and have started driving with the super ten transmission and so far it's real easy exept for when I go to take off on a grade. What happens sometimes is when I go to do a button shift it will go in to neutral and cause me to almost stop or down shift. It only does it if the engine is pulling hard. So what do y'all think I am doing wrong? I have driven a 15 and ten speed and seem to have the hang of that so I had to get used to the super ten. Thanks in advance for your advice.
  3. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,569
    Dec 30, 2017
    Coal Town
  4. Carguy94
    16
    10
    Nov 16, 2017
    Thanks the video helps a lot. I think what i miss sometimes is I'll forget to let all the way off the fuel and then it misses the shift. If it makes any difference I leave my Jakes on high all the time.
  5. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Wind the engine to the redline rpm, and use the engine brake for the 1-2, 3-4 shifts on grades. Don't rush the shifts.
    akfisher and Carguy94 Thank this.
  6. Lyle H
    Lyle H Road Train Member
    1,292
    2,942
    Apr 16, 2014
    At least put a smiley face or a lol when you spew such nonsense.
    Newbies may not get your sense of humor and mistake it for actual advice.
  7. 201
    201 Road Train Member
    12,791
    26,323
    Apr 16, 2014
    high plains colorado
    I disagree on the video. On those, like a 13, I wouldn't preload the button, and then shift the stick. I'd shift the stick, and just before hitting the throttle, click the button, kind of like a button downshift. I think that's how Eaton recommends it done. Preloading the button, I heard, puts wear on the transmission, plus a much easier chance of missing it .
    AModelCat, Bean Jr. and Diesel Dave Thank this.
  8. Carguy94
    16
    10
    Nov 16, 2017
    Thanks for all the input. So the way I was shifting was pre selecting the button and on a hard pull as soon as I let out it would go into nuetral and grind so I'll try waiting till I've made my lever shift to flip the button and ease my shifts. Should I be using the clutch for a button shift? I usually don't use the clutch to shift but not sure if it would help
  9. windsmith
    7,296
    6,032
    Sep 2, 2011
    NEPA
    I drive a super 10. I wasn't being funny. It's what works for me.
  10. Lyle H
    1,292
    2,942
    Apr 16, 2014
    Must not be your truck.
    akfisher Thanks this.
  11. windsmith
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Always pre select. Don't clutch for shifts. Be patient, and don't rush the shifts.
