I have a 1980 Freightliner FLC-12064-T with a early airliner suspension. I have to have 110 PSI before the suspension will air up. Is there a way to change at what pressure it gets air?
Suspension air up pressure?
Discussion in 'Freightliner Forum' started by jorlee, Aug 30, 2011.
Mine airs up at 90psi. I am assuming you could buy a differnt protection valve with a lower psi. You could also remove it all togather, but then if you blow a bag you are going to lose all your air, instead of it cutting off the bag supply at 110.
Any idea where this regulator might be located? or what it looks like?
I would guess somewhere down on the frame between the cab and rear axle. Not really sure where on a Freightliner. Call your dealer and ask where the suspension protection valve is. This is one style. Not saying that it is what is on your truck though.
http://www.haldex.com/Documents/hbsna/Suspension_Controls/Pressure_Protection_Valve_Product_Bulletin_%20L25053_2-03.pdf -
pressure protection ajustment depends on manufacter's recomendation. For 6x4 truck with conventional air suspention system 100 psi is enought if you haul standard loads.
