Suspension cut-off weight
Discussion in 'Trucks [ Eighteen Wheelers ]' started by AModelCat, Jul 21, 2015.
  1. AModelCat
    165,067
    So I've managed to source out a complete KW 8 bag cut-off on 40k rears. I'm trying to determine if my pickup truck will be able to tow it or if I should borrow my dad's pickup since it's bigger. Just wondering if anyone would know off hand approximately what it would weigh? I'm guessing it'd be in the 5-6k lb range maybe?
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    We put a pete air ride cut off single/out steel wheels on the back of a I ton Pick/up flat bed but it made the ft. end bottom out on all bumps, so a short slow trip will be ness.
    AModelCat Thanks this.
  4. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Your correct
    It will be in the 6000 lb range if compleat drum to drum Everything
  5. AModelCat
    165,067
    I'm off to go pick it up tomorrow. Decided to use my dad's 3/4 ton since I have to drive about 250 miles one way to get it. Found out it's complete with 8 tires and a 5th wheel as well so It may be closer to 7k pounds.
  6. Ruthless
    Ruthless Road Train Member
    9,220
    91,616
    Aug 28, 2010
    The City.
    Hope it's not a dodge, you'll be pulling the leaf springs back down thru the bed when you get home :/
  7. AModelCat
    165,067
    Hauling it home right now. Got it on an 8' 6" wide 16' flatdeck. Chevy's pulling it just fine.
    Ruthless Thanks this.
  8. bigguns
    bigguns Road Train Member
    2,846
    6,855
    Jun 13, 2013
    Omega,GA
    Just exactly what air ride is it? I am a big fan of KW but the engineers can't home in on a good air ride. Now I will contradict myself. A short wb '95 that I bought has Airglide 100 and rides like a dream. BUT it is the first really good riding KW I have ever been in. I have KW's version of Pete 380 air ride and I am not impressed by it.
  9. AModelCat
    165,067
    AG100. I lucked out. The frame on the cutoff is the same dimensions as my truck so I can chop the rotten frame off the back end and weld the cutoff right on.
  10. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    What year and model is your truck?
  11. AModelCat
    165,067
    1980 W900. Had to ditch the rubber block. Kidneys hurt just thinking about it lol.
