suspicious SAIA offer.
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by OdderThan, Mar 24, 2026 at 8:08 PM.
  1. OdderThan
    OdderThan Light Load Member
    147
    281
    Sep 9, 2025
    Recently was offered .86cpm by saia in what im assuming is an overnight position.
    Recruiter posted .86cpm as a ltl line haul, out of a midwest corridor.
    Whats the catch?
    The terminal theyre recruiting me out of is small, clean, well lit, and i rarely ever see their drivers hook their own sets, always seems like a drop and hook situation.
    The trucks seem newer or at least new enough to have the led cascadia lights factory.
  3. bad-luck
    bad-luck Road Train Member
    3,438
    6,331
    Nov 16, 2013
    Baltimore, Maryland
    Just curious, did he or she put it in writing?
    Bean Jr. Thanks this.
  4. OdderThan
    147
    281
    Sep 9, 2025
    Technically yes, as it was an official job post offer. Although, they could change that during interviews as most companies try to do.
    Its just roughly .15-.25cpm higher than their postings barely year ago which has me suspicious.
  5. FearTheCorn
    FearTheCorn Heavy Load Member
    753
    2,966
    Jan 6, 2019
    Omaha
    Take it if they throw in the chicks for free.
  6. brian991219
    brian991219 Road Train Member
    3,023
    6,201
    Aug 10, 2013
    Lords Valley, PA
    They have recently raised rates and that isn't that unusual of a rate for Saia linehaul. If it is nights it will be 100% drop and hook, however you will likely build and break sets on one end, if not both, unless it is a meet and turn.
    Their trucks are fairly new. Safety is very firm and has high expectations. They run seniority based eventhough they are non-union so your bid can change.
    My brother worked for them for a while. He loved it, but the job wouldn't have been for me. Too much repitition every night.
  7. bad-luck
    3,438
    6,331
    Nov 16, 2013
    Baltimore, Maryland
    I am sure there is someone here that works for Saia that may be able to give you some insight.
    I have been an owner operator for so long, companies I once thought were ok no longer are.
    Lonesome Thanks this.
  8. Banker
    Banker Road Train Member
    4,518
    14,658
    Aug 19, 2012
    Random Midwest location posted currently. Look at the location on their website for where you want to work and you will probably see the current rate posted the recruiter gave you. IMG_1886.png
  9. Speedy356
    Speedy356 Medium Load Member
    530
    3,302
    Oct 13, 2021
    Ask about the runs and where they go, usually starting out you’ll run 150-200 miles to a hub and then return.
  10. Chinatown
    Chinatown Road Train Member
    77,753
    184,561
    Aug 28, 2011
    Henderson, NV & Orient
    Probably a couple of drivers retired or retiring soon.
