Swap 8LL for 18 Speed
Discussion in 'Kenworth Forum' started by Lowboy456, Jul 7, 2020.
  1. Lowboy456
    Lowboy456 Medium Load Member
    301
    147
    Mar 14, 2017
    Have I lost my mind here? I've looked at the ratios and it seems as though almost every thing in the ratios are very close except that the 18 has a lower and slower normal reverse at 12.85 where the 8LL is 9.85. I like the 8LLs reverse when backing a good ways to the spreader to dump asphalt. 8LLand18SpeedRatios.jpg
    Over drive is nearly identical and 1st, 2nd 3rd and so on are all very close all through out.
    The 18 just gives you the option to grab a half a gear higher literally from anywhere.
    The 8LL is out now so it would be the perfect opportunity to switch If I'm going to. Is there any reason why I shouldn't? I need to let the man know quick as possible.
    This is in a KW T800 Dump Truck with a Cat C-13
  3. Lowboy456
    301
    147
    Mar 14, 2017
    Really? Guess I'm on my own with this one?
  4. tnpete
    tnpete Medium Load Member
    561
    609
    Jun 25, 2013
    Tn
    Being its a dump truck, would stick with the 8LL. But sure like a 18 also. Always hated the times in a tri-axle and had to back a mile down a narrow road to the paver.
  5. Tb0n3
    Tb0n3 Road Train Member
    4,761
    9,686
    Oct 5, 2012
    Earth
    High range reverse is easier with a straight truck :p
