Swapping engine computors
Discussion in 'Freightliner Forum' started by Hawgrunner, Mar 26, 2023.
  1. Hawgrunner
    Hawgrunner Bobtail Member
    Cai I use an 06 engine ecu from a automatic transmission in a 06 engine with a standard shift transmission, sane engines? Both Freightliner Detriots, Thanks.
  3. AModelCat
    159,057
    No, Not a direct plug and play anyways.
    Will definitely need your parameters set in the replacement ECM, as well as injector trim codes. You'll need to find out if the replacement ECM requires reprogramming to go from an automatic transmission to a manual as well.
    Hawgrunner Thanks this.
