Swapping Rims And Tires
Discussion in 'Ask An Owner Operator' started by Adamali21, Aug 7, 2020.
  1. Adamali21
    Adamali21 Light Load Member
    278
    180
    Jul 24, 2018
    Hello Everyone
    Recently I bought my dream truck it’s a kenworth w900, I don’t like the tires because it has low tread, tire size are 11R22.5. Now my older truck which is a Volvo vnl780 has 24.5 tire size and they are still almost brand new. Could I be able to swap rims and tires. Will it effect anything since the W900 is rated tire is are 22.5
    Speed_Drums Thanks this.
  3. Long FLD
    Long FLD Road Train Member
    12,958
    54,394
    Mar 4, 2015
    Are the tires on your Volvo tall or low pro 24.5’s? Tall 22.5’s are about the same diameter as low 24.5’s. Should be an easy swap and you shouldn’t have to do anything with your speedo. But if they’re tall 24.5’s your speedo will be off and you’ll be running a slightly lower rpm at cruising speed.
    Dino soar, Ffx95, Adamali21 and 2 others Thank this.
  4. AModelCat
    165,067
    24.5 are a pretty common tire on a lot of W900s. As long as the steer tires don't hit anything at full left/right turn. Probably just need the speedometer recalibrated.
    Adamali21 Thanks this.
  5. Adamali21
    278
    180
    Jul 24, 2018
    Volvo has 295/75R24.5
  6. Adamali21
    278
    180
    Jul 24, 2018
    Sorry Volvo has 285/75R24.5
  7. Adamali21
    278
    180
    Jul 24, 2018
    Well thank you guys, the W900 has tandem fenders hopefully putting 24.5 won’t rub on the fenders.
  8. Alexander suero
    Alexander suero Light Load Member
    72
    41
    Nov 17, 2018
    Your speedometer will be off 2 miles or less. Nothing else is affected and its a str8 forward exchange
  9. abyliks
    abyliks Road Train Member
    4,150
    9,789
    May 2, 2010
    ludlow MA
    Those are the same height as 1122.5s, as long as the are both hub pilot/ball and socket on either truck they should go right over as long as steel/aluminum is the same spot as well
