Swapping tire size
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Skiharleydoo, Nov 28, 2022.
  1. Skiharleydoo
    Skiharleydoo Bobtail Member
    11
    4
    Jun 12, 2017
    Rockies
    I currently have 11R22.5 tires on my 2022 Western Star 5700XE.
    I’m going to swap to 295/75R22.5.
    How much will my speedometer be off?
    Can a dealer change the settings on the ECM to correct the speedometer?
  3. Gridaxe5588
    Gridaxe5588 Light Load Member
    126
    168
    Nov 23, 2022
    Running the same on my 16 Cascadia and mine is only off 1 MPH.
  4. 062
    062 Road Train Member
    6,324
    33,962
    Oct 20, 2013
    Vehicle Speed Calculator
    It'll vary a little depending on specs and speed, but around 2-4mph. Yes dealer should be able to help.
    Skiharleydoo Thanks this.
  5. aussiejosh
    aussiejosh Road Train Member
    4,798
    5,649
    Aug 28, 2009
    Airlie Beach QLd
    Depends on the diameter if there is not much difference you'll find it will hardly make a difference. I would not worry to much about it. As the police will usually allow most vehicles a certain percentage over the speed limit anyway.
  6. Skiharleydoo
    11
    4
    Jun 12, 2017
    Rockies
    My speedometer was 3mph off with the smaller tires. Updated the ECM to 509 revaluations per mile. Problem solved.
