SWIFT AGAIN & AGAIN & AGAIN
Discussion in 'Trucking Accidents' started by Dave_in_AZ, Jul 9, 2016.
  1. Truckers Report Jobs
  2. Tac-Lift
    Tac-Lift Light Load Member
    54
    58
    May 22, 2012
    If you get a good enough running start it should fit. :rolleyes:
    Dharok, Manny M, mjd4277 and 3 others Thank this.
  3. LindaPV
    LindaPV Medium Load Member
    Not enough lube....
    Dharok, gallegosmike, mjd4277 and 5 others Thank this.
  4. Flashdrive7
    Flashdrive7 Medium Load Member
    646
    1,490
    Apr 24, 2015
    West Coast
    It wasn't his fault. The numbers on the clearance sign aint big enough
    Hamburger71, Dharok, mjd4277 and 3 others Thank this.
  5. MidwestResident
    MidwestResident Road Train Member
    4,325
    4,795
    Sep 20, 2012
    Wichita KS
    http://www.livetrucking.com/semi-truck-almost-makes-it-under-11-foot-overpass/
    • [​IMG]
    Semi truck almost makes it under 11-foot overpass
    A semi truck got stuck under an overpass on Friday afternoon in Pullman, Washington.
    The bridge, located near 16th and Highway 195, was marked with an 11-foot height clearance. According to reports, the driver was not familiar with the area and was following his GPS.
    KHQ Local News posted the following update on their Facebook page:
    KHQ Cynthia Johnson says police told her the truck driver is not from the area, was following his GPS, came to intersection and didn’t realize height danger“
    The road was closed in order to remove the damaged vehicle, but has since reopened.
    w.h.o Thanks this.
  6. Chinatown
    Chinatown Road Train Member
    78,077
    186,245
    Aug 28, 2011
    Henderson, NV & Orient
    He should have downshifted and stomped on the gas pedal.
  7. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Mid roof conversion bridge
    RedRover, Dharok, mjd4277 and 6 others Thank this.
  8. Hick
    Hick Heavy Load Member
    928
    1,624
    Dec 4, 2014
    Even if that bridge wasn't marked, how could you roll up on it and think that the truck was going to fit?
  9. unloader
    unloader Road Train Member
    1,037
    1,156
    Jan 7, 2013
    Exactly. I do a lot of residential deliveries and while I don't have to worry about low bridges, you bet your ### I keep an eye on ALL low hanging telephone and power lines. It a lot of slow and easy. I've backed up down a residential street because of a low hanging wire, just isn't worth the hassle to me. I think I've come across ONE unmarked bridge in my time trucking. No excuses for this ####.
    unloader
  10. Chinatown
    78,077
    186,245
    Aug 28, 2011
    Swift keeps those second chance companies supplied with drivers.
