Swift Questions
Discussion in 'Swift' started by CalculatedRisk, Apr 6, 2023.
  1. CalculatedRisk
    CalculatedRisk Heavy Load Member
    789
    1,000
    Jul 26, 2022
    Space Coast
    Does anyone here drive for the Ocalla terminal? Also, what do they mean by regional? In addition, can anyone tell me their experience I mean, recent experience, going through with a mentor ? Last but not least, what type of insurance do you guys have?
    Hunter
    austinmike Thanks this.
  3. Chinatown
    Chinatown Road Train Member
    77,751
    184,486
    Aug 28, 2011
    Henderson, NV & Orient
    Go with Swift Refrigerated.
  4. Moosetek13
    Moosetek13 Road Train Member
    14,984
    19,034
    Nov 1, 2010
    Burnsville, MN
    Regional means a certain section of the country.
    I run the Great Lakes Region. My area covers the upper mid-west.
    On the western side it is the eastern part of ND and SD, NE, IA down into KS and MO.
    On the eastern side I don't go past Ohio and as far south as a little bit of KY.
    All of the top states in between those.
    Regional pays differently than OTR.
    I think it is 8 cpm more than the OTR rate, but there is no sliding pay scale with regional. You get paid the same rate no matter the length of the run.
  5. dptrucker
    dptrucker Road Train Member
    4,704
    3,239
    May 14, 2012
    adelanto,ca.
    they have medical, dental, eye coverage
    each have a 3 level pay structure depending how much you want to pay.
    taken out of pay each week.
    The_vett and CalculatedRisk Thank this.
  6. CalculatedRisk
    789
    1,000
    Jul 26, 2022
    Space Coast
    What is your idle policy?
  7. Moosetek13
    14,984
    19,034
    Nov 1, 2010
    Burnsville, MN
    They don't like you to idle.
    Many of the trucks have Opti-Idle, some don't. All have the idle regulated with ambient temperatures, although some of the temp sensors are wonky and the computer settings are not always set properly.
    Basically, the engine should idle below ~34 degrees or above ~70. In between those it will shut off after 5 minutes unless Opti-Idle is being used.
    CalculatedRisk Thanks this.
  8. CalculatedRisk
    789
    1,000
    Jul 26, 2022
    Space Coast
    wonder if you have a CPAP like I do? Will they still allow you to idle?
    dptrucker Thanks this.
  9. dptrucker
    4,704
    3,239
    May 14, 2012
    adelanto,ca.
    got to go thru some hoops to get shop to allow truck to idle. didnt feel like it was worth it so i didnt go that route
    really had no issues with using my cpap.
  10. Moosetek13
    14,984
    19,034
    Nov 1, 2010
    Burnsville, MN
    No, I don't.
    The trucks have inverters so power should not be an issue.
    If you have Opti-Idle the truck will run if the battery gets too low, so that should also not be a problem.
    If the truck does not have Opti-Idle, possibly an exception could be made about the idle settings.
  11. NH Guy
    NH Guy Medium Load Member
    610
    2,079
    Feb 26, 2023
    How much power does a CPAP use? Could you plug it into one of those UPS/battery bank things they use for computer power?
