Switch Plate Covers - How to tighten?
Discussion in 'Ask An Owner Operator' started by Hanadarko, Jul 28, 2011.
  1. Hanadarko
    Hanadarko Independent Owner/Operator
    2,971
    935
    Oct 1, 2009
    Midwest
    I was wondering what the trick/secret might be to tighten these switch plates (round ring nut in the center) w/o marring the actual plate?
    I found a 12pt socket that works great on the ring nut but it will marr the finish on this plate....
    Anyone have any thoughts?
  3. rollin coal
    rollin coal Road Train Member
    13,636
    28,031
    Mar 29, 2008
    TN
    Put some scotch tape or masking tape on it might do the trick.
    Hanadarko Thanks this.
  4. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    I use a flat screwdriver. The nuts I have are slotted. They don't need to be crazy tight.
  5. MeatHead
    MeatHead Medium Load Member
    327
    115
    Sep 25, 2009
    They actually make a screw driver for these. Looks like a pitch fork with just 2 prongs. Kind of hard to find. A machine shop can make you one pretty quick and easy
  6. Hanadarko
    2,971
    935
    Oct 1, 2009
    Midwest
    I figured as much....with the switch lever in the way, my only thought was a 12 point tall socket used gently....
  7. MeatHead
    327
    115
    Sep 25, 2009
    Ya know, I just remembered another tool you can buy cheap. It's one to take the cover off a watch to change the battery. They are adjustable and have 2 pins.
  8. Hanadarko
    2,971
    935
    Oct 1, 2009
    Midwest
    That works on the chrome nutz - for the OEM 12 point, I ended up using a 14mm 12pt socket and it worked fine.
    Thanks guys... :biggrin_2559:
