Switching transmission types
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ridgerunner77, Aug 22, 2014.
  1. ridgerunner77
    ridgerunner77 Light Load Member
    78
    25
    Apr 13, 2013
    I have a 2006 freightliner with the 515 detroit with a 10 sp meritor transmission but its maxed at 1550 torque.my question is how hard/difficult/expensive would it be to switch to a eaton trans with a 13 sp with 1650 but 1850 torque preferably.
  3. Pahrump
    Pahrump Medium Load Member
    should bolt right to the bellhousing, your drive shaft will need to be shortened,,
  4. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    If trucks not on warranty.. You should be able to get a shop to turn up torque if you sign a waiver as long as you don't abuse it , tranny will live awhile if it's currently healthy.. There are a lot of guys pushing 300 to 500 ft/lbs over what their tranny is rated for and having no issues, it's all based on the driver
  5. ridgerunner77
    78
    25
    Apr 13, 2013
    I was told by detroit that it would need remapped (fuel) and that since it was at the 1550 max torque they wont supply the remap for it..I had it on the computer and its locked at 1550 at all available hp levels
  6. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    maybe you need to take it to some other person an turn it way up
  7. 55_cans
    55_cans Light Load Member
    98
    19
    Sep 14, 2012
    Alberta
    Might have to upgrade your driveshaft to an 1810 series to use all that torque.
  8. ridgerunner77
    78
    25
    Apr 13, 2013
    So the only thing I have to change is the driveshaft? Nothing wiring or electrical involved? So I assume I need a 13 sp tran, newinput shaft, new clutch, driveshaft and computer upgraded, is that it or am I missing something..also, does it have to be a specific 13 sp or can any go in
