Swr 3.0 no matter
Discussion in 'CB Radio Forum' started by Half Throttle, May 9, 2012.
  1. Half Throttle
    Half Throttle Bobtail Member
    4
    Barbourville, KY
    Ok here is a question not necessarily related to trucks. I have mounted a cb on a Cat D6N and can not get the swr below 3.0. I have it hooked up with 9' of coax and know that most call for 18' but it is no difference if I use 9 or 18 I have tried both. I have an excellent ground since the whole machine is metal. I have the antenna mounted behind cab so that it doesn't get broke due to trees and other things. I have tried Francis antenna and get above 3.0 I have tried fire stick and I get 3.0 I have tried another (brand???) and get 3.0. Like I said earlier I have changed coax to different lengths and it doesn't help. My meter is not broke I can go to my truck and get 1.4 on my setup in it. Does anyone have any suggestions or ideas, tips, tricks?
  3. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    HUMMMMM :biggrin_25513:
    Try a 50 ohm load AT the antenna .... If the meter reads almost 1:1 you problem is AT the antenna if NOT then let us know what you get :biggrin_2556:
    Channel Jumper Thanks this.
  4. Half Throttle
    4
    Barbourville, KY
    I'm sorry but I'm just an ol farm boy from southeastern KY how would I put a test like that on?
  5. Rat
    Rat Road Train Member
    Info on the type of mount you are using???? Is the antenna grounded out???? All antenna mounts have a plastic washer on them that keeps the antenna from grounding out. It is mounted on top of the bracket and insulates the antenna from the bracket.
    If your antenna is not insulated from the mounting bracket then it is grounding or shorting out which will cause excessive SWR.
    Also when you say behind the cab, do you mean directly behind the cab with nothing being above the cab??? If so then that may also be an issue. With the antenna mast being so close to metal and not sticking above the metal then you may also run into high SWR issues. If this is the case, the only fix is to move the antenna either up on top of the cab area or back away from the cab area so that the mast is not so close to the cab. I know, I know, this would put the antenna in danger of being broken or knocked off when working around trees etc but it is the only option.
    I highly suggest getting a steel whip style antenna and getting it above the cab.
    You might also look into a spring to install at the base of the antenna but be aware that you will need to trim some of the antenna to get it to tune properly because the spring actually adds length to the antenna.
  6. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    HUMMM .... :biggrin_25513:
    I'm married to a EASTERN Kentucky Hillbilly who has her general class license :biggrin_2559:
    To test everything from the antenna back you want to put a 50 ohm load
    from hot to ground ACROSS the antenna measure with a ohm meter to see if at the radio connector end of the coax you can see that 50 ohm load and then with your SWR meter again at the connector end see if you have a low swr .....
    If you do then something is amiss with your antenna if it is high still your coax is bad ....
    A SHORT test is short the antenna end and measure at the radio connector end of the coax for that short ....
    COAX is nothing but a way to move your power from the radio to the antenna .....
  7. rollingradios
    rollingradios Light Load Member
    184
    66
    Mar 9, 2012
    Richmond, Va
    See this picture? Make sure that plastic washer is on the top side of the bracket.
  8. Powder Joints
    7,988
    8,406
    Sep 25, 2007
    Rosamond, SoCal
    Sounds like the insulator is missing
  9. Powder Joints
    7,988
    8,406
    Sep 25, 2007
    Rosamond, SoCal
    use a mag mount and be done with it, and that will take care of the breaking worry. Stick it as high as you can.
  10. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    "COAX is nothing but a way to move your power from the radio to the antenna"
    I beg to differ. Coax when cut to a phase angle of 180 degree multiples is nothing more than a way to move your power from radio to antenna. Coax when cut to any other length does the same as above, but also acts as an impedance transformer.
    Look at a 90 degree q section for impedance matching multiple elements.
