SWR Antenna question
Discussion in 'CB Radio Forum' started by HD_Renegade, Dec 27, 2019.
  1. HD_Renegade
    HD_Renegade Road Train Member
    1,470
    607
    Dec 20, 2010
    North Carolina
    Once you set/tune the antenna for a CB radio, will you have to retune the SWR if you change to another radio ?
    Thank you
  3. skellr
    skellr Road Train Member
    8,737
    12,179
    Jul 17, 2011
    The Village, Portmeirion
    Nope.
    It is good to check it from time to time.
    rabbiporkchop, flood and HD_Renegade Thank this.
  4. HD_Renegade
    1,470
    607
    Dec 20, 2010
    North Carolina
    I agree with that. I have 2 different radios. One has a built in digital swr reading when you key the mic. The other has a needle type. Both radios are Stryker, but I was wondering if they both should have the same swr reading ?
  5. skellr
    8,737
    12,179
    Jul 17, 2011
    They should have same reading but the built in meters aren't very accurate. I wouldn't be surprised if they showed different readings.
  6. HD_Renegade
    1,470
    607
    Dec 20, 2010
    North Carolina
    The one on my 447HPC2 is the same reading as my stand alone swr meter.
  7. jessejamesdallas
    1,415
    854
    Oct 3, 2008
    Republic of Texas
    Set it once, and done....Only time you would need to possibly retune the SWR on a antenna is if you move the antenna to a different vehicle or different mounting location...changing radios makes no difference.
  8. Timin770
    Timin770 Road Train Member
    1,611
    1,698
    May 27, 2011
    Canton, GA
    I'd still check VSWR anyway, just for the H of it
    skellr Thanks this.
  9. Windmill Hill
    Windmill Hill Light Load Member
    52
    20
    May 26, 2019
    Central Indiana
    You tune the antenna to the vehicle not the cb...no additional tuning should be required after that unless the antenna is moved within that vehicle or you change any components past the radio i.e. coax, whip, etc..
  10. skellr
    8,737
    12,179
    Jul 17, 2011
    Yeah, it's always good to keep checking it. Lots of exposure to the elements and vibrations, something is going to get fouled up sometime.
    Timin770 and HD_Renegade Thank this.
