SWR Just Wont Behave
Discussion in 'CB Radio Forum' started by Bluethunder1, Aug 24, 2022.
  1. Bluethunder1
    Bluethunder1 Bobtail Member
    Aug 24, 2022
    Hello - we are trying to mount an antenna on a 2015 Ford f150 which has an aluminum frame and non metallic body. I am using a front hood mount, new coax, an external SWR bridge and a Bearcat 980 SSB. When we try using any center, or low, type coil antenna (Hustler or Wilson), we just can not get below 2.0. We tried a 3' fire stick and got a 1.1 match. Any ideas what we may be doing wrong or is this a characteristic of the Ford aluminum bodies?? Appreciate any advice/help...
  3. Ridgeline
    22,744
    123,743
    You need to mount the antenna onto the body, it is aluminum or build a mount that extends through the slot between the box and the cab.
    here is a little info about it
    Ford Super duty Installation Notes
  4. RockinChair
    RockinChair Road Train Member
    5,401
    14,540
    Feb 19, 2012
    Lubbock, TX & thereabouts
    If you're mounting it onto a non-metallic body panel then you may be dealing with all kinds of problems with both RF and DC ground. Perhaps running a ground strap to the frame would help.
  5. Naptown Muduck
    Naptown Muduck Light Load Member
    96
    78
    Jul 30, 2018
    I thought the fords had aluminum bodies. Aluminum is metallic but not magnetic, so you can’t use a mag mount antenna. You can do a through hole mount, but you have to follow specific installation procedures to prevent corrosion between dissimilar metals.
  6. craig_sez
    craig_sez Road Train Member
    5,570
    2,714
    Sep 5, 2013
    novascotia,Canada
    Top loads will be a better choice anyways..
